If you can create a script on your computer to check this condition, you can use a 'Custom Script' for OnGuard.
Original Message:
Sent: Jan 23, 2024 07:16 AM
Subject: Use OnGuard settings to block sharing internet connection from PC
Hello Mates,
When configuring OnGuard SHV pluging, i noticed that there are some features that can prevent from using PC as a hotspot to share internet connection to other devices.
When i tried to configure it, i still can use my pc as a hotspot. Is there some specific configuration i should do, in order to block it ?
Please note that the " check for network connection types" bottom is unchecked.
Thank you everyone.
