Use only 1 ssid WIPS
  • 1.  Use only 1 ssid WIPS
    Posted Apr 02, 2018 09:13 PM
    I use topic because of one problem in using Aruba controller.
    I use WIPS.
    However, I would like to ask you if there are some conditions.
    1) Use WIPS as a whole.
    2) Some ssid not controlled
    (ex. Aruba SSID :           aruba_1   used
                                           aruba_2   used
           Unknown SSID :      test_1      used
                                            test_2      block(WIPS))
    1) was successful.
    But something happened during the 2) course of the play.
    Any advice is appreciated!
    Edward Jung.
  • 2.  RE: Use only 1 ssid WIPS
    Posted Apr 02, 2018 09:52 PM
    What WIPS policy would you like to enforce? WIPS is general.  What would you  like to do specifically?
  • 3.  RE: Use only 1 ssid WIPS
    Posted Apr 02, 2018 10:22 PM
    For example, two SSID on the Aruba controller work normally.
    And there are two SSID visible elsewhere.
    (One is normal , one is block)
    If so, can I configure WIPS to block only one of the two?
  • 4.  RE: Use only 1 ssid WIPS
    Posted Apr 02, 2018 10:30 PM
    What do you want to block?
  • 5.  RE: Use only 1 ssid WIPS
    Posted Apr 02, 2018 10:39 PM
    I want to block only the SSID I want.
    example,
    ssid_1, ssid_2, ssid_3, ssid_4
    ssid_1 block
    ssid_2 not block
    ssid_3 block
    ssid_4 not block
    Is it possible?
  • 6.  RE: Use only 1 ssid WIPS
    Posted Apr 02, 2018 11:01 PM
    You want to block clients from connecting to SSID1 and SSID3?  If you have encryption or authentication enabled, wouldn't that block them?
  • 7.  RE: Use only 1 ssid WIPS
    Posted Apr 02, 2018 11:06 PM
    Blocks even if it is encrypted or authenticated.
    Regardless of the type of SSID (OPEN, encryption, authentication), can I block only what I want through WIPS?
  • 8.  RE: Use only 1 ssid WIPS
    Posted Apr 03, 2018 04:03 AM
    What are you blocking?  WIPS can block because of a type of behavior.  What behavior are we blocking?
  • 9.  RE: Use only 1 ssid WIPS
    Posted Apr 03, 2018 04:48 AM
    sorry, it 's my mistake.
    We were not using a wips license.
    I made a really big mistake.
    I'll try it again.
