Use role_id guest user attribute for MAC authentication
This thread has been viewed 41 times
  • 1.  Use role_id guest user attribute for MAC authentication
    Posted Nov 10, 2020 09:58 AM
    Hi
    I would like to use  for authorization purpose role_id attribute in MAC authentication. I have a self-registration captive portal with mac -caching, and I would like the customer to be able to change user roles from guest user database, so when devices associated to that user re-connect to be able to have the attributes of the new role.
    So far I have tried with some codes I found in other posts with some changes:
    SELECT tgu.attributes->>'Role ID' AS role_id FROM tips_guest_users as tgu WHERE tgu.guest_type = 'DEVICE' AND tgu.user_id = UPPER('%{Endpoint:Username}')
    Adding a new attribute at Authentication Sources->Guest user repository, and then use that authorization attribute in role mapping but no luck so far.
    Can anyone help me?
    Regards
    Marcos Gonzalez
  • 2.  RE: Use role_id guest user attribute for MAC authentication
    Posted Nov 11, 2020 11:14 AM
    Device Role ID is available by default in [Guest Device Repository]
    Tim C
  • 3.  RE: Use role_id guest user attribute for MAC authentication
    Posted Nov 11, 2020 11:31 AM
    Hi. Yes I know, but I'm talking about [Guest User Repository].
    Marcos Gonzalez
  • 4.  RE: Use role_id guest user attribute for MAC authentication
    Posted Nov 11, 2020 11:37 AM
    MAC Authentication does not use that auth source.
    Tim C
  • 5.  RE: Use role_id guest user attribute for MAC authentication
    Posted Nov 11, 2020 11:43 AM
    Hi Tim.
    Actually you can use Authorization attributes like user expired, or user enabled, and there are many references in other posts that you can use custom attributes, but I don't get to work the SQL query for role_id attribute
    Regards
    Marcos Gonzalez
  • 6.  RE: Use role_id guest user attribute for MAC authentication
    Posted Nov 11, 2020 11:47 AM
    Use GuestUser:Role ID then.
    Tim C
  • 7.  RE: Use role_id guest user attribute for MAC authentication
    Posted Nov 12, 2020 04:10 AM
    That's what I'm trying, but role_id is not pre-defined as authorization attribute in guest user repository source definition on cppm:
    So, I'm tryng to add a new custom attribute :
    With a custom SQL Query similar to this:
    That query is the one that is not working for me.
    Marcos Gonzalez
  • 8.  RE: Use role_id guest user attribute for MAC authentication
    Posted Nov 12, 2020 04:21 AM
    Hi, after several tries it appear that the correct SQL query is this one:
    SELECT tgu.attributes->>'Role ID' AS role_id FROM tips_guest_users as tgu WHERE tgu.guest_type = 'USER' AND tgu.user_id = '%{Endpoint:Username}'
    Marcos Gonzalez
  • 9.  RE: Use role_id guest user attribute for MAC authentication
    Posted Nov 12, 2020 10:19 AM
    GuestUser:Role ID is automatically created and is not based on [Guest User Repository] filters.
    You should not use Endpoint attributes when referencing Guest data directly.
    Tim C
