Use Wifi as Uplink, and bridge Eth ports
  • 1.  Use Wifi as Uplink, and bridge Eth ports
    Posted Jun 24, 2013 04:15 PM
    Is it possible to connect an instant/RAP3 using wifi as it's uplink, and then bridge E0,E1,E2 to it?  I want to use the instant/RAP as a wireless bridge with multiple ethernet ports.
  • 2.  RE: Use Wifi as Uplink, and bridge Eth ports
  • 3.  RE: Use Wifi as Uplink, and bridge Eth ports
    Posted Jul 10, 2014 11:47 AM
    I do evrething but in "Info" "Uplink type: Ethernet" never been change! RAP3 in Instant mode, fw 6.4.0.2. And i no see any attempt to connect RAP to wifi. What can i chek in settings? System > Uplink window in attach.
  • 4.  RE: Use Wifi as Uplink, and bridge Eth ports
    Posted Jul 10, 2014 11:58 AM
    Are you attempting to connect the RAP-3 to other Aruba IAPs or 3rd party APs?  If connecting to Aruba APs no configuration is necessary and the RAP-3 will join as part of the Mesh network.  WiFi uplink is only used to connect Aruba to 3rd party.
  • 5.  RE: Use Wifi as Uplink, and bridge Eth ports
    Posted Sep 23, 2014 07:43 PM
    I've tried connecting a RAP3 as a mesh, and connecting it to a third party AP, and it never comes up.  Is Mesh and wifi uplink only available in dual radio iAPs?
  • 6.  RE: Use Wifi as Uplink, and bridge Eth ports
    Posted Sep 24, 2014 12:35 AM
    That's correct, Mesh only works on dual APs
