Purchased used IAP's, did a factory reset, and installed ok. However, IOS location services and PC map applications return wrong address. I assume it was the previous location for these IAP's. How do I teach them the right location?
Please see the post here: http://community.arubanetworks.com/t5/Wireless-Access/Is-skyhook-the-location-provider-Aruba-access-points-use-Is/m-p/238118
I didn't see a solution in the link that was responded. I did see a refernece to "advertise-location enabled in the WLAN SSID Profile" But I don't find that setting in the virtual controller. Any other clues?
Advertise-location is not related to what you are trying to do. In the thread there is a link that says how to opt out of location services by changing your SSID name.
Thanks, but I didn't see a link to what you referenced to opt out of location services by changing SSID. Please resend the link.
