I have many devices that are not domain computers who connect to my SSID "Corpo".
On this SSID, enforce machine authentication is check, machine default role and user default role ok.
When this equipment connect to network, authentication process through radius and default role is good, I use a DHCP fingerprinting option to assign a new role to this equipment (printer) and it work fine.
But after controller upgrade/reboot, these printers reconnect with the default user role, not going to there user derivation rules...rebooting the device dont work, I have to power off device, "delete aaa user x.x.x.x", the restart it. Is there a way easier then that cause I plan to install another 200 of these in the same mode. I can always switch the new one to a PSK SSID bypassing the "enforce machine authentication / user derivation rules" problem but that is plan B.
Any idea of the cause and / or a solution?
Andre Boucher
