User Drop and Association Issue. Unable to associate Ipad Mini-2 devices to Aruba WAP
  • 1.  User Drop and Association Issue. Unable to associate Ipad Mini-2 devices to Aruba WAP
    Posted Jan 11, 2017 07:46 PM
    Hi Aruba team,
    In the latest firmware 6.5.0.0-4.3.0.0_56428, once the defined user limit is reached for both 2.4GHz and 5GHz radio's, the following issues are seen.
    1. Few users are being dis-associated
    2. The dropped users can never be connected to the network again.
    3. Remove(dis-associate) some of the users from 5GHz and try to connect them again. They cannot be associated again.
    I have used the following commands for configuring "user Limits for Per-AP Radio Profiles".
    a. a-max-clients <ssid_profile> <max-clients>
    b. g-max-clients <ssid_profile> <max-clients>
    Impacted Devices: The above mentioned issues are seen only with "IPAD MINI-2". devices. However, with all other types of devices such as Android or other Ipad devicecs(such as Ipad Air2, IPad Mini4), it just works fine.
    Observation: While investigating, I have noticed that, Aruba is rejecting the user authentication requests with Status code 17.  The logs captured on the aruba side is pasted below.
    Logs:18:64:72:c8:4f:ac# show a-max-clients profile-1
    a-max-clients: 10
    18:64:72:c8:4f:ac# show g-max-clients profile-1
    g-max-clients: 5
    18:64:72:c8:4f:ac#
    Meanwhile, when logged into Aruba to ensure the AID limit is not reached(confirmed by show ap association command) also verified, the user limit is NOT reached.
    Logs for reference:
    18:64:72:c8:4f:ac# show ap debug mgmt-frames
    Traced 802.11 Management Frames
    Timestamp        stype   SA                 DA                 BSS                signal  Misc
    Dec  3 20:19:15  deauth  18:64:72:04:fa:c3  c0:f2:fb:19:7d:32  18:64:72:04:fa:c3  15      - (internal only)
    Dec  3 20:19:10  deauth  18:64:72:04:fa:d3  6c:70:9f:7a:ff:33  18:64:72:04:fa:d3  15      - (internal only)
    Dec  3 20:19:10  deauth  18:64:72:04:fa:d3  c0:f2:fb:19:7d:32  18:64:72:04:fa:d3  15      - (internal only)
    Dec  3 20:19:05  deauth  18:64:72:04:fa:c3  6c:70:9f:7a:ff:33  18:64:72:04:fa:c3  15      - (internal only)
    Dec  3 20:18:40  auth    18:64:72:04:fa:c3  c0:f2:fb:09:4d:67  18:64:72:04:fa:c3  15      AP is resource constrained (seq num 0)
    Dec  3 20:18:40  auth    c0:f2:fb:09:4d:67  18:64:72:04:fa:c3  18:64:72:04:fa:c3  0       -
    Dec  3 20:18:40  auth    18:64:72:04:fa:d3  c0:f2:fb:09:4d:67  18:64:72:04:fa:d3  15      AP is resource constrained (seq num 0)
    Dec  3 20:18:40  auth    c0:f2:fb:09:4d:67  18:64:72:04:fa:d3  18:64:72:04:fa:d3  0       -
    Dec  3 20:18:40  auth    18:64:72:04:fa:c3  c0:f2:fb:19:7d:32  18:64:72:04:fa:c3  15      AP is resource constrained (seq num 0)
    Dec  3 20:18:40  auth    c0:f2:fb:19:7d:32  18:64:72:04:fa:c3  18:64:72:04:fa:c3  0       -
    Dec  3 20:18:39  auth    18:64:72:04:fa:d3  c0:f2:fb:19:7d:32  18:64:72:04:fa:d3  15      AP is resource constrained (seq num 0)
    Dec  3 20:18:39  auth    c0:f2:fb:19:7d:32  18:64:72:04:fa:d3  18:64:72:04:fa:d3  0       -
    Dec  3 20:18:34  auth    18:64:72:04:fa:c3  6c:70:9f:7a:ff:33  18:64:72:04:fa:c3  15      AP is resource constrained (seq num 0)
    Dec  3 20:18:34  auth    6c:70:9f:7a:ff:33  18:64:72:04:fa:c3  18:64:72:04:fa:c3  0       -
    Dec  3 20:18:34  auth    18:64:72:04:fa:d3  6c:70:9f:7a:ff:33  18:64:72:04:fa:d3  15      AP is resource constrained (seq num 0)
    Dec  3 20:18:34  auth    6c:70:9f:7a:ff:33  18:64:72:04:fa:d3  18:64:72:04:fa:d3  0       -
    Dec  3 20:18:33  auth    18:64:72:04:fa:c3  c0:f2:fb:19:7d:32  18:64:72:04:fa:c3  15      AP is resource constrained (seq num 0)
    Dec  3 20:18:33  auth    c0:f2:fb:19:7d:32  18:64:72:04:fa:c3  18:64:72:04:fa:c3  0       -
    Dec  3 20:18:33  auth    18:64:72:04:fa:d3  c0:f2:fb:19:7d:32  18:64:72:04:fa:d3  15      AP is resource constrained (seq num 0)
    Dec  3 20:18:33  auth    c0:f2:fb:19:7d:32  18:64:72:04:fa:d3  18:64:72:04:fa:d3  0       -
    Dec  3 20:18:32  auth    18:64:72:04:fa:c3  c0:f2:fb:19:7d:32  18:64:72:04:fa:c3  15      AP is resource constrained (seq num 0)
    Dec  3 20:18:32  auth    c0:f2:fb:19:7d:32  18:64:72:04:fa:c3  18:64:72:04:fa:c3  0       -
    Dec  3 20:18:32  deauth  18:64:72:04:fa:c3  c0:f2:fb:19:7d:32  18:64:72:04:fa:c3  15      CM: Band Steer (seq num 0)
    Dec  3 20:18:31  auth    18:64:72:04:fa:c3  c0:f2:fb:11:ec:f1  18:64:72:04:fa:c3  15      AP is resource constrained (seq num 0)
    Dec  3 20:18:31  auth    c0:f2:fb:11:ec:f1  18:64:72:04:fa:c3  18:64:72:04:fa:c3  0       -
    Let me know if you need any specific log. I can provide it.
    Thank you.
  • 2.  RE: User Drop and Association Issue. Unable to associate Ipad Mini-2 devices to Aruba WAP
    Posted Jan 11, 2017 07:52 PM
    What is your question?
  • 3.  RE: User Drop and Association Issue. Unable to associate Ipad Mini-2 devices to Aruba WAP
    Posted Jan 11, 2017 08:02 PM
    The question is: Why do I have user connectivity issue when user limitation per profile is not reached? I have set user limit as 15(10 for 5GHz and 5 for 2.4GHz) on the profile however, only 10 users are connected and unable to connect more.
    Please take time to go through my previous post where I have listed all the issues.
  • 4.  RE: User Drop and Association Issue. Unable to associate Ipad Mini-2 devices to Aruba WAP
    Posted Jan 11, 2017 08:18 PM
    It could be a bug.  That parameter is rarely used.  I would open a TAC case so that they can replicate it with your configuration.
  • 5.  RE: User Drop and Association Issue. Unable to associate Ipad Mini-2 devices to Aruba WAP
    Posted Jan 11, 2017 08:57 PM
    Thank you Colin. Really appreciate your help.
  • 6.  RE: User Drop and Association Issue. Unable to associate Ipad Mini-2 devices to Aruba WAP
    Posted Jan 11, 2017 09:19 PM
    That per SSID radio limit was first introduced in Instant 4.3.0.0., so there could be an issue with it.
  • 7.  RE: User Drop and Association Issue. Unable to associate Ipad Mini-2 devices to Aruba WAP
    Posted Jan 12, 2017 06:05 AM
    A hidden warning I see is that this should not be combined with Band Steering or Client Match enabled.
  • 8.  RE: User Drop and Association Issue. Unable to associate Ipad Mini-2 devices to Aruba WAP
    Posted Jan 12, 2017 02:37 PM
    The issue still seen my WAP. I disabled both the client-match feature as well as band-steering.
    Below, the settings from my Aruba WAP:
    18:64:72:c8:4f:ac# show arm config
    Minimum Transmit Power            :10
    Maximum Transmit Power            :10
    Band Steering Mode       :disable
    Client Aware             :enable
    Scanning                 :disable
    Wide Channel Bands       :5ghz
    80Mhz Support            :enable
    160Mhz Support           :none
    Air Time Fairness Mode   :fair-access
    Client Match             :disable
    CM NB Matching Percent   :60
    CM Calculating Interval  :3
    CM SLB Threshold         :5
    CM SLB Client Threshold  :30
    CM SLB Balancing Mode    :channel based
    CM Max Request           :5
    CM Max Adoption          :5
    CM Hold Time             :300
    CM Good SNR              :30
    CM Bad SNR               :18
    CM SNR Threshold         :10
    CM VBR Report Interval   :30
    CM VBR Stale Entry Age   :300
    CM STA Stale Entry Age   :1000
    CM Restriction Timeout   :10
    CM Debug Level           :error
    Custom Channels          :Yes
    2.4 GHz Channels
