User eertificate error when connecting
  • 1.  User eertificate error when connecting
    Posted Feb 14, 2013 09:21 PM
    Hi All,
    Thanks before hand for reading/helping on the following:
    I have a deployed a comp-user cert scenario validation (windows 7 - Aruba controller - NPS) and does work fine when comp validates itself using comp cert (before login)
    The issue starts when client send user details. The following its some of tog entry that Im able to paste for your perusal
    Feb 13 18:53:11  station-up             *  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92                        -      -    wpa2 aes
    Feb 13 18:53:11  eap-id-req            <-  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92                        1      5
    Feb 13 18:53:11  eap-start             ->  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92                        -      -
    Feb 13 18:53:11  eap-id-resp           ->  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92                        1      22   DOMAIN\username
    Feb 13 18:53:11  rad-req               ->  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92                        65457  218
    Feb 13 18:53:11  rad-resp              <-  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92/COW-NPS-radius server  65457  90
    Feb 13 18:53:11  eap-req               <-  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92                        2      6
    Feb 13 18:53:11  eap-nak               ->  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92                        2      6
    Feb 13 18:53:11  rad-req               ->  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92/COW-NPS-radius server  65458  240
    Feb 13 18:53:11  rad-reject            <-  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92/COW-NPS-radius server  65458  44
    Feb 13 18:53:11  eap-failure           <-  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92                        2      4    server rejected
    Feb 13 18:53:31  eap-id-req            <-  00:26:82:09:16:c2  d8:c7:c8:2b:6d:9a                        18     5
    Feb 13 18:53:35  station-up             *  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        -      -    wpa2 aes
    Feb 13 18:53:35  station-data-ready     *  00:24:d7:05:63:cc  00:00:00:00:00:00                        101    -
    Feb 13 18:53:35  wpa2-key1             <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        -      117
    Feb 13 18:53:35  eap-start             ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        -      -
    Feb 13 18:53:35  eap-id-req            <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        2      5
    Feb 13 18:53:41  eap-id-req            <-  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92                        3      5
    Feb 13 18:54:01  eap-id-req            <-  00:26:82:09:16:c2  d8:c7:c8:2b:6d:9a                        19     5
    Feb 13 18:54:05  eap-id-req            <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        2      5
    Feb 13 18:54:11  eap-id-req            <-  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92                        4      5
    Feb 13 18:54:31  eap-id-req            <-  00:26:82:09:16:c2  d8:c7:c8:2b:6d:9a                        19     5
    Feb 13 18:54:35  eap-id-req            <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        2      5
    Feb 13 18:54:41  eap-id-req            <-  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92                        4      5
    Feb 13 18:55:01  eap-id-req            <-  00:26:82:09:16:c2  d8:c7:c8:2b:6d:9a                        19     5
    Feb 13 18:55:05  eap-failure           <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        2      4    station timeout
    Feb 13 18:55:05  eap-id-req            <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        3      5
    Feb 13 18:55:11  eap-id-req            <-  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92                        4      5
    Feb 13 18:55:31  eap-id-req            <-  00:26:82:09:16:c2  d8:c7:c8:2b:6d:9a                        20     5
    Feb 13 18:55:35  eap-id-req            <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        3      5
    Feb 13 18:55:41  eap-id-req            <-  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92                        5      5
    Feb 13 18:56:01  eap-id-req            <-  00:26:82:09:16:c2  d8:c7:c8:2b:6d:9a                        20     5
    Feb 13 18:56:05  eap-id-req            <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        3      5
    Feb 13 18:56:11  eap-id-req            <-  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92                        5      5
    Feb 13 18:56:31  eap-id-req            <-  00:26:82:09:16:c2  d8:c7:c8:2b:6d:9a                        20     5
    Feb 13 18:56:35  eap-id-req            <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        4      5
    Feb 13 18:56:41  eap-id-req            <-  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92                        5      5
    Feb 13 18:57:01  station-down           *  00:26:82:09:16:c2  d8:c7:c8:2b:6d:9a                        -      -
    Feb 13 18:57:05  eap-id-req            <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        4      5
    Feb 13 18:57:11  station-down           *  74:de:2b:a5:ae:5d  d8:c7:c8:2b:6d:92                        -      -
    I'd like to mention that I have deployed comp-user cert scenario in my LAB (only Windows default policies) and works fine. Replicating same scenario in PROD produces de above (btw, PROD environment uses lots more AD policies)
    Cheers,
  • 2.  RE: User eertificate error when connecting
    Posted Feb 14, 2013 09:43 PM
    • Is your goal to use only computer certificates; or also use both computer and then user certificates when the user logs on?
    • At the time of the failed user attempt; can you send what the NPS logs report?
  • 3.  RE: User eertificate error when connecting
    Posted Feb 14, 2013 11:59 PM
    Hi Clembo (thanks for your promptly reponse),
    Its the plan to achieve the use of computer and user certificate. The below describe current problem further;
    1.        LAB Environment
    Client set up to use EAP-TLS for machine and user login
    PC is member of domain and both machine and user certificate is installed in client.
    Once pc is boot up it successfully connected to network using machine certificate.
    Feb 13 18:36:08  eap-start             ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             -   -
    Feb 13 18:36:08  eap-id-req            <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             22  5
    Feb 13 18:36:08  eap-id-resp           ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             22  31   host/AAT33100.LAB.LOCAL
    Feb 13 18:36:08  rad-req               ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             63  238
    Feb 13 18:36:08  rad-resp              <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  63  90
    Feb 13 18:36:08  eap-req               <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             23  6
    Feb 13 18:36:08  eap-resp              ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             23  167
    Feb 13 18:36:08  rad-req               ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  64  412
    Feb 13 18:36:08  rad-resp              <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  64  232
    Feb 13 18:36:08  eap-req               <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             24  148
    Feb 13 18:36:08  eap-resp              ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             24  69
    Feb 13 18:36:08  rad-req               ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  65  314
    Feb 13 18:36:08  rad-accept            <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  65  242
    Feb 13 18:36:08  eap-success           <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             24  4
    Feb 13 18:36:08  station-data-ready     *  00:24:d7:21:10:e4  00:00:00:00:00:00             41  -
    Feb 13 18:36:08  m-auth cache           *  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             -   -
    Feb 13 18:36:08  wpa2-key1             <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             -   117
    Feb 13 18:36:08  wpa2-key2             ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             -   119
    Feb 13 18:36:08  wpa2-key3             <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             -   151
    Feb 13 18:36:08  wpa2-key4             ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             -   95
    User initiates logging (ALT+CLT+DEL) and user connected to network succesfully.
    Feb 13 18:36:21  eap-start             ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             -   -
    Feb 13 18:36:21  eap-id-req            <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             26  5
    Feb 13 18:36:21  eap-id-resp           ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             26  23    username@LAB.LOCAL
    Feb 13 18:36:21  rad-req               ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             66  222
    Feb 13 18:36:21  rad-resp              <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  66  90
    Feb 13 18:36:21  eap-req               <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             27  6
    Feb 13 18:36:21  eap-resp              ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             27  132
    Feb 13 18:36:21  rad-req               ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  67  369
    Feb 13 18:36:21  rad-resp              <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  67  1188
    Feb 13 18:36:21  eap-req               <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             28  1096
    Feb 13 18:36:21  eap-resp              ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             28  6
    Feb 13 18:36:21  rad-req               ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  68  243
    Feb 13 18:36:21  rad-resp              <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  68  1188
    Feb 13 18:36:21  eap-req               <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             29  1096
    Feb 13 18:36:21  eap-resp              ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             29  6
    Feb 13 18:36:21  rad-req               ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  69  243
    Feb 13 18:36:21  rad-resp              <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  69  371
    Feb 13 18:36:21  eap-req               <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             30  285
    Feb 13 18:36:21  eap-resp              ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             30  1492
    Feb 13 18:36:21  rad-req               ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  70  1739
    Feb 13 18:36:21  rad-resp              <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  70  90
    Feb 13 18:36:21  eap-req               <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             31  6
    Feb 13 18:36:21  eap-resp              ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             31  406
    Feb 13 18:36:21  rad-req               ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  71  645
    Feb 13 18:36:21  rad-resp              <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  71  153
    Feb 13 18:36:21  eap-req               <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             32  69
    Feb 13 18:36:21  eap-resp              ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             32  6
    Feb 13 18:36:21  rad-req               ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  72  243
    Feb 13 18:36:21  rad-accept            <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4/LAB_NPS  72  242
    Feb 13 18:36:21  eap-success           <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             32  4
    Feb 13 18:36:21  station-data-ready     *  00:24:d7:21:10:e4  00:00:00:00:00:00             41  -
    Feb 13 18:36:21  m-auth resp            *  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             -   -     authenticated
    Feb 13 18:36:21  wpa2-key1             <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             -   117
    Feb 13 18:36:22  wpa2-key1             <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             -   117
    Feb 13 18:36:23  wpa2-key1             <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             -   117
    Feb 13 18:36:23  wpa2-key2             ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             -   119
    Feb 13 18:36:23  wpa2-key3             <-  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             -   151
    Feb 13 18:36:23  wpa2-key4             ->  00:24:d7:21:10:e4  d8:c7:c8:a8:86:e4             -   95
    Above setup work sucessfully in lab
    1. 2.        PROD environment
    Aruba and NPS configured same as Lab
    Feb 14 09:43:12  station-up             *  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        -    -     wpa2 aes
    Feb 14 09:43:12  eap-id-req            <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        1    5
    Feb 14 09:43:12  eap-start             ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        -    -
    Feb 14 09:43:12  eap-id-resp           ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        1    39    host/Computerclient.prod.local
    Feb 14 09:43:12  rad-req               ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        29   252
    Feb 14 09:43:12  rad-resp              <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a/PROD-NPS-radius server  29   90
    Feb 14 09:43:12  eap-req               <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        2    6
    Feb 14 09:43:12  eap-resp              ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        2    105
    Feb 14 09:43:12  rad-req               ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a/PROD-NPS-radius server  30   356
    Feb 14 09:43:12  rad-resp              <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a/PROD-NPS-radius server  30   1188
    Feb 14 09:43:12  eap-req               <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        3    1096
    Feb 14 09:43:12  eap-resp              ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        3    6
    Feb 14 09:43:12  rad-req               ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a/PROD-NPS-radius server  31   257
    Feb 14 09:43:12  rad-resp              <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a/PROD-NPS-radius server  31   1188
    Feb 14 09:43:12  eap-req               <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        4    1096
    Feb 14 09:43:12  eap-resp              ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        4    6
    Feb 14 09:43:12  rad-req               ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a/PROD-NPS-radius server  32   257
    Feb 14 09:43:12  rad-resp              <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a/PROD-NPS-radius server  32   287
    Feb 14 09:43:12  eap-req               <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        5    203
    Feb 14 09:43:13  eap-resp              ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        5    1492
    Feb 14 09:43:13  rad-req               ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a/PROD-NPS-radius server  33   1753
    Feb 14 09:43:13  rad-resp              <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a/PROD-NPS-radius server  33   90
    Feb 14 09:43:13  eap-req               <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        6    6
    Feb 14 09:43:13  eap-resp              ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        6    825
    Feb 14 09:43:13  rad-req               ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a/PROD-NPS-radius server  34   1082
    Feb 14 09:43:13  rad-resp              <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a/PROD-NPS-radius server  34   153
    Feb 14 09:43:13  eap-req               <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        7    69
    Feb 14 09:43:13  eap-resp              ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        7    6
    Feb 14 09:43:13  rad-req               ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a/PROD-NPS-radius server  35   257
    Feb 14 09:43:13  rad-accept            <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a/PROD-NPS-radius server  35   218
    Feb 14 09:43:13  eap-success           <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        7    4
    Feb 14 09:43:13  station-data-ready     *  00:24:d7:05:63:cc  00:00:00:00:00:00                        101  -
    Feb 14 09:43:13  wpa2-key1             <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        -    117
    Feb 14 09:43:13  wpa2-key2             ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        -    119
    Feb 14 09:43:13  wpa2-key3             <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        -    151
    Feb 14 09:43:13  wpa2-key4             ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        -    95
    User initiates logging (ALT+CLT+DEL) and failed
    Feb 14 09:44:37  eap-start             ->  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        -    -
    Feb 14 09:44:37  eap-id-req            <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        9    5
    Feb 14 09:45:07  eap-id-req            <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        9    5
    Feb 14 09:45:37  eap-id-req            <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        9    5
    Feb 14 09:46:07  eap-failure           <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        9    4     station timeout
    Feb 14 09:46:07  eap-id-req            <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        10   5
    Feb 14 09:46:37  eap-id-req            <-  00:24:d7:05:63:cc  d8:c7:c8:2b:6d:9a                        10   5
    No logs in NPS regards user logging attempts.  Looking at Aruba auth-trace-buff, client did not respond to eap-id request.  We were unable to enable local event logger in client due to group policy restrictions.
    Config extract
    !machine and user role set to allow all only for testing
    user-role sh-corp-machine-role
     access-list session allowall
    user-role sh-corp-user-role
    aaa server-group "PROD-NPS-Server Group"
       allow-fail-through
     auth-server "PROD-NPS-radius server"
    aaa profile "corp-aaa_prof"
       mac-default-role "logon"
       authentication-dot1x "NPS-corp-802.1x-authprofile"
       dot1x-server-group "PROD-NPS-Server Group"
       radius-accounting "PROD-NPS-Server Group"
    ! termination on controller un-ticked.
    aaa authentication dot1x "NPS-corp-802.1x-authprofile"
       machine-authentication enable
       machine-authentication machine-default-role "sh-corp-machine-role"
       machine-authentication user-default-role "sh-corp-user-role"
       timer idrequest_period 5
       server server-retry-period 5
       termination eap-type eap-tls
    ! only wpa2-aes selected
    wlan ssid-profile "corp-ssid_prof"
       essid "ssid-corp"
       opmode wpa2-aes
    wlan virtual-ap "corp-vap_prof"
       aaa-profile "corp-aaa_prof"
       vlan 101
       dos-prevention
       band-steering
    (some of the "names" were modified intentionally to prevent security disclose)
