Aruba Instant Wi-Fi: Meet the controllerless Wi-Fi solution that's easy to set-up, is loaded with security and smarts, and won't break your budget.
user interface https://instant.arubanetworks.com:4343/#home is not working
This thread has been viewed 19 times
  • 1.  user interface https://instant.arubanetworks.com:4343/#home is not working
    Posted Aug 29, 2022 02:05 PM
    Hi, I'm not able to change / delete networks, neighter to use maintanance (nothing is available). System was setup with Aruba Central as management. Thx.
  • 2.  RE: user interface https://instant.arubanetworks.com:4343/#home is not working
    Posted Aug 29, 2022 06:41 PM
    once IAP cluster is managed by Aruba Central then you need to configure it from Aruba Central.
    so go to your Aruba Central and make your changes from there.
  • 3.  RE: user interface https://instant.arubanetworks.com:4343/#home is not working
    Posted Aug 30, 2022 02:20 AM
    Hi ,
    I need some help in updating the certificate of captive portal  i have imported certificate in the configuration-- system-- certificate here i ahve imported the certificate but I don't know where to call this certificate in the captive portal so that the certificate should. Be updated pleas suggest thanks in advance
  • 4.  RE: user interface https://instant.arubanetworks.com:4343/#home is not working
    Posted Aug 30, 2022 03:09 AM
    That question about updating the certificate is unrelated to this topic. Please open your own topic/discussion, and add version, AP-type, management method, type of cert, etc.
  • 5.  RE: user interface https://instant.arubanetworks.com:4343/#home is not working
    Posted Sep 01, 2022 07:23 AM
    Hi, I have setup central some time ago with an employee account - since some time I'm not working with HPE. I'm not able to access to Central with my old HPE account an with a new account central is answering that the devices are blocked (while I'm trying to add. them.
    Thx.
  • 6.  RE: user interface https://instant.arubanetworks.com:4343/#home is not working
    MVP GURU
    Posted Sep 01, 2022 07:42 AM
    You should work with TAC to resolve that issue :)
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 7.  RE: user interface https://instant.arubanetworks.com:4343/#home is not working
    Posted Sep 01, 2022 09:42 AM
    ... there are many URL - can you pls. provide the right one? Thx Dustin
  • 8.  RE: user interface https://instant.arubanetworks.com:4343/#home is not working
    MVP GURU
    Posted Sep 01, 2022 09:59 AM
    asp.arubanetworks.com
    Dustin Burns
