User Management For Controller
  • 1.  User Management For Controller
    Posted May 30, 2013 01:06 AM
    There are an option for user to access this controller :
    root
    read-only
    network-operations
    location-api-mgmt
    guest-provisioning
    Is there any role for the user to get some limited access to the controller so they cannot access to the configuration. maybe just monitoring all Access Points or maybe not all of the Access Point but only 1 group of the Access Point.
    Thx
  • 2.  RE: User Management For Controller
    Posted May 30, 2013 01:29 AM
    Nope that does not exist ... you just can put those roles you listed....
    I actually think i put a feature request on the partner site about this already...
    Cheers
    Carlos
  • 3.  RE: User Management For Controller
    Posted May 30, 2013 01:32 AM
    Actually i also put it in the ideas tab...
    You can kudo it to suppport the idea... to see if they put it, on the newest firmwares
    Cheers
    Carlos
