User Role after MAC Auth
  • 1.  User Role after MAC Auth
    Posted Mar 30, 2016 01:32 PM
    Hi:
    I'm working with mac auth in a test environment using the controller's internal database.
    Even though I've set a "MAC Authentication Default Role" in the aaa profile, the role that gets assigned to the user is coming from the user entry in the internal database.
    Is there a way to have the aaa proflie's MAC auth default role be assigned?
    There does not seem to be a way to delete the internal database role in the GUI.
    Tony
  • 2.  RE: User Role after MAC Auth
    Posted Mar 30, 2016 01:42 PM
    If you are using the server-group "default" or "internal" it would have a derivation rule as below.
    aaa server-group "default"
    auth-server Internal
    set role condition role value-of
    Try deleting the rule or create a different server-group that doesn't have the derivation rule.
  • 3.  RE: User Role after MAC Auth
    Posted Mar 30, 2016 02:02 PM
    Thank you.
    Yes, the default server group was in use.
    I had forgotten about that.
    All is well with a shiny, new server group!
    Thank you!
