You will need firmware
16.08 16.06 or up
to get support for the vlan-id-tagged (or 16.08 for multiple tagged VLANs in a role). That probably is not a solution as the 3500 does not support that, but it is an explanation why it doesn't work.
Original Message:
Sent: May 27, 2021 06:41 AM
Subject: User role and tagged VLAN -HP Switch-
Thank you Derin, yes, I've used it with legacy HP switches successfully. But in this specific scenario, I need to use "user-roles" in the own switch, then I need to configure the tagged vlan inside this role:
aaa authorization user-role name {user-role name}
policy {policy-name}
vlan-id-tagged {vlan id}
The problem is that these HP switches only give me the chance of use "vlan-id" and no "vlan-id-tagged" so I can only set untagged vlans.
tech_sec
Original Message:
Sent: May 27, 2021 04:25 AM
I don't have any direct experience of the HP3500 but on other legacy HP switches I have successfully used IETF (RFC4675) Egress-VLANID attribute - see https://community.arubanetworks.com/community-home/digestviewer/viewthread?MID=7032
Derin Mellor
Original Message:
Sent: May 26, 2021 07:11 PM
I am deploying roles in my switches (HP 3500). My CPPM sent the role name to the switches and I am deploying a VLAN linked to the role in the switch configuration. All is working fine but when I want to set a tagged VLAN, I've not found a way to perform it with HP switches (K16.02 version).
I have looking for information about it and I can see that inside role configuration, in Aruba switches there is a command to make that "vlan-id-tagged X" I've tried to configure it in my HP switches but they only give me the option of configure an untagged VLAN "vlan-id X".
Do you know if there is any way of configure a tagged VLAN linked to a user-role in HP switches with K16.02 versión?
Thanks in advance.
Best regards,
tech_sec
