USER-ROLE replacement fails after AOS-SW is authenticated by CPPM
  • 1.  USER-ROLE replacement fails after AOS-SW is authenticated by CPPM
    Posted Feb 05, 2020 10:41 PM
    Attachment is the authentication record and switch configuration. Please help.
    Thank you
    Attachment(s)
    txt
    SW-Config.txt   2 KB 1 version
    zip
    DashboardDetails.zip   7 KB 1 version
  • 2.  RE: USER-ROLE replacement fails after AOS-SW is authenticated by CPPM
    Posted Feb 06, 2020 05:22 AM
    How are you trying to replace the role? Is that with Change of Authorization? Does the initial authentication apply a role correctly?
    What does the switch say about the authentication (show port-access clients # detail; with # the port number)?
    Anything in the switch logs (show log -r)?
  • 3.  RE: USER-ROLE replacement fails after AOS-SW is authenticated by CPPM
    Posted Feb 10, 2020 09:08 PM
    Hi Herman Robers
    Thank you for your help. I have learned the wrong configuration after switching the Log. After modification, I can see the wired USER on the controller
