user role vlan issue
  • 1.  user role vlan issue
    Posted Jul 22, 2013 01:23 PM
    I am trying to setup assigning VLAN based on user role.  I have user roles CMISO (vlan 900) and CMAUTH (vlan 220) configured.  I have created a test VAP/ESSID where the inital role is CMISO but the client pulls an ip from the vlan of the mgmt interface of the controller (VLAN 10).  The only way to get the client to pull an address not from VLAN 10 is to set the VLAN under the VAP.  However it still ignores the VLAN setting in the user profile.
    I am running 6.2.1.1
  • 2.  RE: user role vlan issue
    Posted Jul 22, 2013 01:29 PM
    You can set the VLAN under the user-role.
    Is that VLAN is up and already exist on the controller ?
    DO  the following:
    show vlan
    show profile-errors
    And also make sure that the VLAN is on your trunks back to the uplink switch if that is how you have it setup .
  • 3.  RE: user role vlan issue
    Posted Jul 22, 2013 01:33 PM
    I did a show profile-errors and there are none.
  • 4.  RE: user role vlan issue
    Posted Jul 22, 2013 01:40 PM
    Can you please share your user-role config ?
  • 5.  RE: user role vlan issue
    Posted Jul 22, 2013 01:42 PM
    user-role CMAuth
    vlan 220
    access-list session allowall
    access-list session v6-allowall
    user-role CMISO
    vlan 900
  • 6.  RE: user role vlan issue
    Posted Jul 22, 2013 01:51 PM
    Make sure your aaa profile config for your VAP is configure to match the user role appropriately .
    Are you trying to do Mac auth ? Do you have a Mac auth aaa profile ?
    What type authentication are you using under your SSID profile ?
  • 7.  RE: user role vlan issue
    Posted Jul 22, 2013 01:58 PM
    yes we are trying mac auth.  the aaa config in the vap point to the appropriate user roles.
    no auth under ssid profile
  • 8.  RE: user role vlan issue
    Posted Jul 22, 2013 02:14 PM
    It looks you on the right track
    I have attached a couple screenshots see if any of those can help you out
  • 9.  RE: user role vlan issue
    Posted Jul 22, 2013 02:24 PM
    Rebuilt my mac-auth profile and seems to be working again.  not sure what happened.  thx for help!!
  • 10.  RE: user role vlan issue
    Trunks exist and are up.  If I set the VAP vlan to 900 or 220 I am able to pull an ip address in the appropriate vlan.  It is when the VAP vlan is "not configured" I pull from the mgmt vlan.
