  • 1.  User Roles
    Posted Jul 10, 2014 03:04 AM
    I'm trying to achieve dot1x authentication where radius server returns private-group-id which determines the role of the client. I wrote Server-Derivation Rule for that. But the issue is how will I configure it in ap configuration side? I created aaa profiles for each vlan.
    I want single ssid and single ap group. The vap profile of the ssid will include all the vlans. But how can I associate all of the user roles with one ssid profile in one ap group. Is this such a thing possible or neccesarry? Any help will be appreciated!
  • 2.  RE: User Roles
    Posted Jul 10, 2014 03:31 AM
    Try to use the attribute FilterID instead.
    I think private-group-id attribute needs to be used in conjunction with a couple of others to work properly.
  • 3.  RE: User Roles
    Posted Jul 10, 2014 03:42 AM
    Right now my friend who can configure radius is not avaible. After I created the post I monitored the traffic between controller and radius. The Radius-Access-Accept message contains user-name credential. I changed the attribute to user-name and the magic worked!  I see that private-group-id is not working properly. I will investigate how can I use it for future use:). And I will try the FilterID later.
    Is there maximum limit for server-derivation rules in numbers?
  • 4.  RE: User Roles
    Posted Jul 10, 2014 03:53 AM
    The private-group-id is used for for vlan derivation.
    http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Network_Parameters/About_VLAN_Assignments.htm#network_parameters_2319977163_1017188
    I don't know if there is a limit on the number of server rules you can have, but wouldn't want it to be too large.
  • 5.  RE: User Roles
    Posted Jul 10, 2014 04:42 AM
    Thank you for your answers. It really helped me.
  • 6.  RE: User Roles
    Posted Jul 10, 2014 04:51 AM
    Your welcome.  Happy to help.
    :smileyhappy:
  • 7.  RE: User Roles
    MVP
    Posted Jul 10, 2014 04:53 AM
    Try returning the Aruba specific VSA aruba-user-role and you don't even need to configure the server rules.
    When the controller receives the aruba-user-role attribute it automatically puts the user into that role.
