  • 1.  User Rules
    Posted Aug 28, 2014 09:19 AM
    I'm trying to apply a user rule to our primary SSID to put Windows XP devices into a limited role. I was testing with moving a specific mac address into a new role and I can see the number of hits incrementing but the set role is never applied.
    Here is where I am applying it to the AAA profile:
    It seems that I'm missing something and I was hoping for a nudge in the right direction.
    Rosie
  • 2.  RE: User Rules
    Posted Aug 28, 2014 09:23 AM
    what role did it get applied ?
  • 3.  RE: User Rules
    Posted Aug 28, 2014 09:25 AM
    The role it gets is from the radius server rules passed by NPS.
  • 4.  RE: User Rules
    Posted Aug 28, 2014 09:28 AM
    You cannot override a rule sent as a VSA
  • 5.  RE: User Rules
    Posted Aug 28, 2014 09:30 AM
    Do you know if I can create an NPS rule to set role based on a dhcp fingerprint? I account for all login cases via the VSA so it sounds like user deravations wouldn't work at all then.
    Eric
  • 6.  RE: User Rules
    Posted Aug 28, 2014 09:32 AM
    I don't believe NPS can profile a device or use DHCP fingerprints.
    Does this SSID serve only corp assets or BYOD as well?
    If they're all domain joined, you can script the creation of a group with all the xp machines in it and use that group in your policy.
  • 7.  RE: User Rules
    Posted Aug 28, 2014 09:38 AM
    The SSID serves all users and none of the machines should be joined to the domain anymore. Most of them are BYOD.
  • 8.  RE: User Rules
    Posted Aug 28, 2014 09:33 AM
    take a look here:
  • 9.  RE: User Rules
    Posted Aug 28, 2014 09:39 AM
    @SethFiermonti wrote:
    take a look here:
    Thanks for the visual!
