Users are able access VPN through Guest Network without going through guest authentication
  • 1.  Users are able access VPN through Guest Network without going through guest authentication
    Posted Sep 30, 2015 07:14 AM
    Hello Guys,
    Users connected to guest network aree able to establish VPN tunnels to outside world without going through Guest authentication. Does anyone know which ports do I have to block for Guest access?
  • 2.  RE: Users are able access VPN through Guest Network without going through guest authentication
    Posted Sep 30, 2015 07:22 AM
    Create a new guest logon role with just DHCP, dns, and captive-portal.
    Tim
  • 3.  RE: Users are able access VPN through Guest Network without going through guest authentication
    Please share the result of the following for the role the guest is in BEFORE authentication.   If you are not sure of the role, check with "show user-table"
    show rights <NameofRole>
  • 4.  RE: Users are able access VPN through Guest Network without going through guest authentication
    Posted Sep 30, 2015 07:42 AM
    Hi Celmbo,
    As reqyested, please find the details about the Guest-pre auth role attached.
    Attachment(s)
    txt
    Guest-Pre-Auth.txt   6 KB 1 version
  • 5.  RE: Users are able access VPN through Guest Network without going through guest authentication
    Posted Sep 30, 2015 08:37 AM
    Hello Guys,
    Any changes in the role which you recommend after looking at the Guest_Pre_auth role?
  • 6.  RE: Users are able access VPN through Guest Network without going through guest authentication
    Posted Sep 30, 2015 08:38 AM
    Create a new guest logon role with just DNS, DHCP and captive-portal...
  • 7.  RE: Users are able access VPN through Guest Network without going through guest authentication
    Posted Sep 30, 2015 08:39 AM
    Try removing line 5 in the logon-control ACL (svc-natt).    You should not need this in your default logon role.    Or if you are more comfortable, make a new logon-control for your needs and leave the default ACL as is.
  • 8.  RE: Users are able access VPN through Guest Network without going through guest authentication
    Posted Sep 30, 2015 10:22 AM
    Thank you guys, I have made the chage and have asked the users to test it. I will update you when I know more.
    Again really appreciate your help!
