User's devices not deleted
  • 1.  User's devices not deleted
    Posted Jul 16, 2014 07:04 AM
    Hi to all,
    I've ClearPass 6.3.4.6 and when I delete an user from Onboard+WorkSpace->View By User, a pop-up windows reports that all user's devices and TLS client certificates will be removed (please check the attach).
    After deleting an user, the user's devices are still present in Onboard+Workspace->View By Device.
    Is it a bug?
    Thanks a lot.
  • 2.  RE: User's devices not deleted
    Posted Jul 16, 2014 12:19 PM
    What do you have set for your retention time. If the field is blank like I have below then it should remove them. If not then they will sit in your CPPM until that time is met.
  • 3.  RE: User's devices not deleted
    Posted Jul 17, 2014 03:36 AM
    Hi tarnold,
    thanks for your reply.
    My fields (minimum and maximum periods) are already blank, but the user's devices are still present..
  • 4.  RE: User's devices not deleted
    Posted Jul 17, 2014 03:42 AM
    Then please open a TAC case. Sounds like you may have run into a bug.
  • 5.  RE: User's devices not deleted
    Posted Jul 17, 2014 03:55 AM
    Ok,
    thanks for your time.
