user's session limit in Captive Portal
  • 1.  user's session limit in Captive Portal
    Posted Dec 03, 2014 06:56 PM
    Hello.
    In Captive Portal profile there is option "Allow only one active user session". When that option is unchecked, it means unlimited number of users (of course limited to platform capacity) can use the same account at the same time or is it limited to certain value?
  • 2.  RE: user's session limit in Captive Portal
    Posted Dec 03, 2014 07:32 PM
    Limited to only a single session while you have the button checked.  Any user who has a matching username will not be allowed if there is another session with the same username.
     http://www.arubanetworks.com/techdocs/ArubaOS_64_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/show_aaa_authentication_.htm?Highlight=Allow only one active user session
  • 3.  RE: user's session limit in Captive Portal
    Posted Dec 03, 2014 08:56 PM
    Yes, it's clear when the button is checked but I asked about number of sessions when the button is unchecked. Is there any limit?
  • 4.  RE: user's session limit in Captive Portal
    Posted Dec 03, 2014 08:57 PM
    noap.
  • 5.  RE: user's session limit in Captive Portal
    Posted Dec 03, 2014 09:01 PM
    OK. Thanks.
  • 6.  RE: user's session limit in Captive Portal
    Posted Feb 13, 2015 08:33 AM
    Thanks for the discussion on this topic.  It is very helpful.
