Seems like you found the issue already.
Original Message:
Sent: Apr 27, 2024 10:49 AM
Subject: Using an AP-225 as a home stand alone Access point
Hi Herman
I have acquired what has been described as an IAP-325 (see image of label on rear), however when I power this up, I can not detect a broadcast SSID of the format SetMeUp
This is what I should expect isn't it?
Any Ideas?
Many thanks
Andy
Original Message:
Sent: Apr 16, 2024 10:19 AM
For standalone operations you would need an IAP-225 model. The AP-225 requires a controller to operate.
Original Message:
Sent: Apr 15, 2024 11:41 AM
I have acquired an AP-225 and want to set it up on my home network to act as another Wi-Fi Access point, but it doesn't seem to to broadcast an SSID so I cant connect to it to set it up. I have tried a factory reset.
Is this possible.
Many thanks
