Wired Intelligent Edge
Using Ansible with raw commands
This thread has been viewed 23 times
  • 1.  Using Ansible with raw commands
    Posted Oct 13, 2018 02:14 PM
    I am nearly up and running with my Ansible set-up and while I can do raw commands to a Cisco, I am not getting the same from Aruba,
    Any ideas how I can use the raw module to write configs ?
    Also is there a good repository for looking at playbooks and get some ideas?
  • 2.  RE: Using Ansible with raw commands
    MVP GURU
    Posted Oct 14, 2018 08:25 AM
  • 3.  RE: Using Ansible with raw commands
    Posted Oct 14, 2018 08:29 AM
    I was hoping for ProVision OS, 3810, 2930,
    I have found the Aruba Github there is only a few ideas on there, I wanted build an repository.
    Although i have only labed Comware 7 in GNS3, but will also be getting on AOS-CX in the near future.
    Andy
  • 4.  RE: Using Ansible with raw commands
    Posted Oct 15, 2018 12:12 PM
    Greetings!
    If you're looking to run a CLI command (or a batch of commands) on ArubaOS-Switch via Ansible, you would want to use the CliCommand or CliBatchCommand REST API methods. These methods accept either a single command or a set of commands that are executed directly, as if they were being run at the CLI prompt. For more details, refer to the Rest API Guide for ArubaOS-Switch 16.07 (these methods are listed on page 47) and the 16.07 REST API and JSON Schema.
  • 5.  RE: Using Ansible with raw commands
    Posted Oct 16, 2018 05:12 PM
    Aruba developed Ansible modules for ArubaOS-Switches.
    You can find out public github for ansible here - https://github.com/aruba/aruba-switch-ansible
    Wiki on how to install modules - https://github.com/aruba/aruba-switch-ansible/wiki/ArubaOS-Switch-Modules-Examples
  • 6.  RE: Using Ansible with raw commands
    Posted Oct 17, 2018 04:17 AM
    Thanks for links, I have still be unable to get it working. I am trying to convert from Network CLi to understanding programing and dont have a comminuty to work through some of the problems.
    I got it working with Cisco easily, but getting the Comware or Aruba working seems to be a bigger challenge.
    I know i have a steep learning curve but i would rather learn on Aruba then Cisco, as it applies to enviroment and career.
  • 7.  RE: Using Ansible with raw commands
    Posted Oct 17, 2018 02:06 PM
    We do have a new Developer Community right here on Airheads where you can ask questions, request feedback, and see the latest programmability innovations on Aruba platforms. Feel free to join and start participating!
  • 8.  RE: Using Ansible with raw commands
    Posted Feb 28, 2019 02:12 PM
    Is the API supported on 3800s in Stack mode running KB.16.08.0001?
    From the documentation: "Aruba REST API Guide for ArubaOSSwitch 16.08"
    ​"Restrictions
    • Rest interface is not supported in FIPS.
    • Rest Interface is not supported on ArubaOS 3800 stack switches."
    If this is true, its a grave diappointment because we have mostly 3800 stacks to manage via automation and Aruba seems to have put all their cards in their API.
  • 9.  RE: Using Ansible with raw commands
    Posted Feb 28, 2019 03:01 PM
    The REST API is fully supported on 3810 stacks in 16.08 (and has been since at least 16.05); this is an error in the REST API guide and we will get it corrected ASAP.
    Thank you for pointing this out to us!
  • 10.  RE: Using Ansible with raw commands
    Posted Feb 28, 2019 03:29 PM
    Thanks for the fast reply!
