last person joined: 11 hours ago
Using AP-205s with IPSec
  • 1.  Using AP-205s with IPSec
    Posted Oct 16, 2014 01:22 PM
    Any guidance on how to configure AP-205s to use IPSec with certificate authentication? When I provision the AP-205 through the GUI (Aruba OS 6.4.2.2) there is no option available to set the AP as a Remote AP.
    Are the AP-205s capable of being set up as Remote AP with Remote AP Authentication set as Certificate?
    #AP205
  • 2.  RE: Using AP-205s with IPSec
    Posted Oct 16, 2014 01:56 PM
    The AP-205 can operate as  RAP; and does has a TPM module for cert-based authentication support.    Can you send a screenshot of the provisioning page of an AP-205?  It should have an Authentication Method section; which includes Remote AP options.
    #AP205
  • 3.  RE: Using AP-205s with IPSec
    Posted Oct 16, 2014 02:06 PM
    Please find attached a screen shot of the provisioning page for an AP-205.
    #AP205
    Attachment(s)
    docx
    ProvPageAP205.docx   80 KB 1 version
  • 4.  RE: Using AP-205s with IPSec
    Posted Oct 16, 2014 02:34 PM
    Can you try a different browser or even a different machine?   The format of that page does not look correct, for example the section under AP Installation Mode typically is under the Authentication section.
    #AP205
  • 5.  RE: Using AP-205s with IPSec
    Posted Oct 16, 2014 02:40 PM
    It was the browser.  I was using firefox and tried it with Chome and the GUI provisioning page looks correct. Thanks for your help.
    #AP205
