last person joined: 10 hours ago
Using Clearpass with EOL hardware.
  • 1.  Using Clearpass with EOL hardware.
    Posted May 31, 2012 12:58 PM
    I have a number of AP85's & 65's that are part of networks that we build in Haiti after the earthquake.
    Some of that equipment is no longer required in the current location and I am looking at redeployment options.
    As I saw a Clearpass presentation at a recent Airheads conference (and was very impressed by it) I am trying to determine if I could use Clearpass for any of the new networks.
    It's not clear to me if this is compatible with these EOL AP's as well as the 800 & 2400 controllers that we use.
    Has anyone got an informed opinion on this?
    Thanks!
  • 2.  RE: Using Clearpass with EOL hardware.
    Posted May 31, 2012 02:41 PM
    You certainly can.
  • 3.  RE: Using Clearpass with EOL hardware.
    Posted Jun 01, 2012 06:05 PM
    I agree with Colin.  As long as the controller supports RADIUS enforcement, you can use it with CPPM.
  • 4.  RE: Using Clearpass with EOL hardware.
    Posted Feb 11, 2015 10:58 AM
    Hi, i'm having deployment with old devices also.
    is it possible to do CoA with controller running ArubaOS 5?
    Ricky.
  • 5.  RE: Using Clearpass with EOL hardware.
    Posted Feb 15, 2015 08:00 AM
    i advise against jumping on threads that are 3 years old with a new question. just start a new thread with a clear description.
    when i look at the ArubaOS 5.0 user guide i see the RFC 3576 server being mentioned so i assume it support CoA.
    [edit] and some threads later (i always start with the oldest) you did start a new thread and solved your issue.
