When the user is logged with the Email registration SSID (Test1)I can run a command from the local controller.
>show user-table | INCLUDE 192.168.103.76
This will output:
IP MAC Name Role Age(d:h:m) Auth VPN link AP name Roaming Essid/Bssid/Phy Profile Forward mode Type Host Name User Type
.76 ##.## Petros@ guest ## Web Blank ##### Wireless ####### Guest-Email Tunnel Limux ##### WIRELESS
When the user is logged with the Noral GUest Wifi that uses a user account (vast) SSID (VAST) I can run a command from the local controller.
>show user-table | INCLUDE 192.168.103.144
This will output:
.144 ## vast , VAST-Guest-post-auth, Web ## Wireless ###### Test2-Vast tunnel Linux WIRELESS
So the question is how can I get the new Guest Email registration profile of 'Guest-Email' to use the 'VAST-Guest-post-auth' role? Or will I need to change the local guest role - rules to match the: VAST-Guest-post-auth role rules?
Stavros K
Original Message:
Sent: Aug 21, 2024 05:04 PM
Subject: Using Email Registration for Guest Portal Access
My company has been using a local user account, that I have manually created on the Aruba Local Controllers, for Guest WiFi access. I have set this up using the 'Interactive Captive Portal with authentication' template. That process has been working well for years and I typically change that password every 6 months.
It has now been suggested that I should try and setup a different type of Guest login process on the Aruba Controllers. Specifically I should try to setup the 'Interactive Captive Portal with email registration' template. I have tried to set this new way but i am having a problem with post authentication.
After I authenticate the user has a guest profile instead of the desired post authentication profile that I have selecte din the 'Group' --> 'Configuration' --> 'L3 Authentication' --> 'Captive Portal Authentication' --> 'SSID_Name' --> 'Default Role'.
The only difference in the new SSID is using a 'Guest Login' instead of the 'User Login' option. Which is located in the L3 Authentication Captive Portal Authentication section. Please see attachment.
The problem is that the new SSID is not only allowing access to the internet but it is allowing access to the internal network as well and I think it is because i tis using the 'Guest Login' option instead of the 'User Login' option.
Stavros K
