Yes to both questions, but it may be best to test/prepare this with your Aruba partner and/or Aruba Support in order to make that change smooth.
Be advised that running the 9004 as ArubaOS 8.x gateway will probably require licenses, where when running from Central in SD-Branch mode it uses subscriptions from Central and the local licenses are no longer needed. Also, at this point in time it may be good for new SD-Branch deployments to deploy the gateway in AOS-10 mode. Your local Aruba partner or local Aruba SE should be able to assist you with making the best decision on more information that we have here on the forum.
Original Message:
Sent: Sep 01, 2022 02:49 PM
Subject: Using Gateway/Controller as a router until SD-Branch
Couple of questions about Aruba's controllers and sd-branch. Thank you in advance.
1. Can i use Aruba 9004 Gateway as a router for a branch which only have one mpls uplink to a head office data center.
2. Can i change the mode of the aruba gateway from controller/gateway mode to a Sd-branch gateway mode after deploying aruba central at the data center end.
I am only exploring this solution until i get the funds to deploy aruba central and deploy aruba sd-wan sd-branch solution.
