Education - Australia / New Zealand
last person joined: 8 days ago
A local community of education customers across Australia / NZ. This group will be moderated by HPE Aruba Networking staff and kept up to date with any upcoming training or events that are relevant to the EDU space.
Using GVRP/MVRP to simplify your network
This thread has been viewed 62 times
  • 1.  Using GVRP/MVRP to simplify your network
    Posted Jun 28, 2016 10:46 AM
    Overview
    I have been using GVRP in my networks for many years. It is a very effective way of distributing VLANs, and in particular, avoiding the need to correctly configure every single switch-to-switch link with the correct set of untagged and tagged VLAN mappings. In environments where there are multiple switches between endpoints, just adding a single VLAN and manually distributing it can be a significant effort, and prone to errors.
    GVRP/MVRP propagates the VLAN IDs only - not the names. It is also a standard, unlike the proprietary VTP that has caused so much consternation in the past.
    GVRP/MVRP
    • GVRP has been deprecated in favour of the more recent MVRP.
    • MVRP grew out of GVRP, and has more features and controllability.
    • GVRP has been available in the ProCurve switches for many years
    • ProCurve switches that support the 16.x firmware (now being rebadged as ArubaOS-Switch) also support MVRP.
    • The Comware 7 switches have had MVRP for a few years now.
    General Process
    1. For simplicity, configure a common VLAN across all switches to use as the untagged (native/PVID) VLAN.
      You could leave this as VLAN 1, but a different VAN is probably a good idea
    2. Enable GVRP/MVRP (globally)
      [for MVRP you also need to enable each port that will send/receive MVRP traffic.]
    3. Make any port-specific or VLAN specific customisation
    VLAN Propagation Example
    Switch 1
    This is a 2915 at the end of an MSM wireless mesh link; GVRP packets are sent over this link to the upstream switch. Just by typing in "vlan 1234", it will show up across the network (where it has not been blocked).
    bvtv09(vlan-1234)# sh vlans 1234
     Status and Counters - VLAN Information - VLAN 1234
      VLAN ID : 1234
      Status : Port-based
      Voice : No
      Jumbo : No
      Port Information Mode     Unknown VLAN Status
      1                Auto     Block        Up
    In this case the uplink is on port 1. Note the mode is Auto.
    On the same switch, you can see that VLAN 930 has port 10 specifically untagged, but port 1 has been automatically configured by GVRP to carry VLAN 930.
    bvtv09(vlan-1234)# sh vlans 930
     Status and Counters - VLAN Information - VLAN 930
      VLAN ID : 930
      Status : Port-based
      Voice : No
      Jumbo : No
      1                Auto     Block        Up
      10               Untagged Learn        Down
    Switch 4
    This is 3 hops away from Switch 1 (the 2915 above). It is connected to its upstream switch on port 24, and has another downstream switch on port 23. Once GVRP was enabled on all the switches, not a single additional interaction was required to get a new VLAN connected through to the downstream Switch 5. (In this case, the full path was 2915 --> 5406 --> Comware 5130 --> 3810 --> 2910, with the 5130 running MVRP.)
    3810M(config)# sh vlans 1234
      VLAN ID : 1234
      Status : Dynamic
      Voice :
      Jumbo : No
      Private VLAN :
      Associated Primary VID : none
      Associated Secondary VIDs : none
      23               Auto     Learn        Up
      24               Auto     Learn        Up
    Extra Config Options
    GVRP port options
    bvcore01(eth-B22)# unknown-vlans
     learn                 Accept join requests for new VLANs on this port and
                           propagate requests through all other forwarding ports
                           that are participating in GVRP.
     block                 Only process GRVP packets that concern themselves with
                           known VLANs and ignore new VLANs.
     disable               Ignore all GVRP packets.
    Unknown-vlans block is a useful port command to stop a switch learning new VLANs. This is sometimes used at the edge rather than the core or distribution switches. If the switch only knows about VLANs 1-10, it will never learn VLANs 11-4094. However, if you add a VLAN (eg 1234), it will automatically tag itself to the uplink port.
    The output below is from Switch 2 (5406).
    bvcore01(config)# sh gvrp
     GVRP support
      Maximum VLANs to support [256] : 256
      Primary VLAN : DEFAULT_VLAN
      GVRP Enabled [No] : Yes
      Port   Type       | Unknown VLAN Join  Leave Leaveall
      D21    100/1000T  | Disable      20    300   1000
      D22    100/1000T  | Learn        20    300   1000
      D23    100/1000T  | Block        20    300   1000
      D24    100/1000T  | Learn        20    300   1000
      Trk3   Trunk      | Learn        20    300   1000
      Trk8   Trunk      | Learn        20    300   1000
    bvcore01(config)# sh run int d24,d23,d21
    Running configuration:
    interface D21
       name "Cable modem LAN4"
       broadcast-limit 10
       unknown-vlans disable
       no power-over-ethernet
       untagged vlan 255
       spanning-tree admin-edge-port
       spanning-tree root-guard
       exit
    interface D23
       name "behind desk"
       unknown-vlans block
       untagged vlan 254
       no snmp-server enable traps link-change
       exit
    interface D24
       name "docking station"
       dhcp-snooping trust
       untagged vlan 145
       exit
    Static-VLAN
    One of the issues is thatoften comes up is how to add ports to a dynamic VLAN. To convert the dynamic VLAN to a static VLAN: static-vlan <id>
    New Feature Device Profile
    If you create a device profile that includes a non-existent VLAN (1234 in the example below), it will be created and the port placed in it when an aruba-ap is plugged in. If you also have GVRP/MVRP enabled, it will automatically be connected via the trunk port(s) and propagate elsewhere. This works on all Aruba IAPs and APs, and not on the POE-powered 7005 controller!
    bvcore01(config)# sh device-profile config
    Device Profile Configuration
    Configuration for device-profile : default-ap-profile
    untagged-vlan : 1
    tagged-vlan : None
    ingress-bandwidth : 100%
    egress-bandwidth : 100%
    cos : None
    speed-duplex : auto
    poe-max-power : 33W
    poe-priority : critical
    allow-jumbo-frames: Disabled
    Configuration for device-profile : BV-Aruba-APs
    untagged-vlan : 1234
    tagged-vlan : None
    cos : None
    speed-duplex : auto
    poe-max-power : 33W
    poe-priority : high
    Device Profile Association
    Device Type : aruba-ap
    Profile Name : BV-Aruba-APs
    Device Status : Enabled
    bvcore01(config)# sh device-profile status
    Device Profile Status
    Port Device-type Applied device profile
    B10 aruba-ap BV-Aruba-APs
    bvcore01# sh vlans 1234
    VLAN ID : 1234
    Status : Port-based
    Voice :
    Jumbo : No
    Private VLAN :
    B10 DEV-PROF Learn Up
    Overridden Port VLAN configuration
    Port Mode
    Note the new DEV-PROF mode (similar to Auto).
    References
    https://en.wikipedia.org/wiki/Multiple_Registration_Protocol#Multiple_VLAN_Registration_Protocol
    http://www.hp.com/rnd/support/config_examples/gvrp_use.pdf Using GVRP (Dynamic VLANs)
    http://community.hpe.com/t5/ProCurve-ProVision-Based/GVRP-Best-Pratice/td-p/4051663 GVRP - Best Practice?
    http://community.hpe.com/t5/Switches-Hubs-Modems-Legacy/Allow-all-VLANs-on-trunk/td-p/5870765 Allow all VLANs on trunk
  • 2.  RE: Using GVRP/MVRP to simplify your network
    Posted Apr 14, 2018 04:32 AM
    When running in an environment with only MVRP (like you can do with all the AOSS devices, or later model ProCurve switches with the AOSS 16.xx firmware), the "unknown-vlan block" option does not stop new VLANs from appearing on the switch.
    Note the "MVRP_100  dynamic" VLAN in the example below.
    AIS-2920-04(config)# sh vlans
      Maximum VLANs to support : 256
      Management VLAN :
      VLAN ID Name                             | Status     Voice Jumbo
      1       DEFAULT_VLAN                     | Port-based No    No
      2       Null                             | Port-based No    No
      8       Aruba Instant AIS                | Port-based No    Yes
      10      Platinum-Gold-Sponsors           | Port-based No    No
      11      AIS-Wireless-Delegates           | Port-based No    No
      12      AIS-Wireless-Podium              | Port-based No    No
      13      AIS-Wireless-Sponsors            | Port-based No    No
      100     MVRP_100                         | Dynamic          No
      930     HPE-Roadshow                     | Port-based No    Yes
      931     OOBM                             | Port-based No    No
    With MVRP, this is resolved by using "mvrp registration fixed".
    The following extract is for the port on a 2920 where the unwanted dynamic VLAN was coming from.
    AIS-2920-04(config)# sh run int 24
    interface 24
       mvrp enable
       untagged vlan 930
       exit
    Now the unwanted dynamic VLAN 100 is not appearing on the switch.
    AIS-2920-04(eth-24)# sh vlans
      Management VLAN :
    The upstream switch will show matching dynamic VLANs if they are added added here; the "fixed" option only blocks the unknown incoming VLANs.
  • 3.  RE: Using GVRP/MVRP to simplify your network
    Posted May 23, 2019 06:00 AM
    I have an issue with device-profile, mvrp and tagged profiles.
    Switch 2930F firmware WC.16.08.0001
    IAP-228-RW in Campus Mode (ArubaMC-VA,8.4.0.0)
    Switch learns dynamic vlans through mvrp from uplink and it works well.
    interface 2
      mvrp enable
      tagged vlan 1
    exit
    Our WiFi uses 802.1x with Radius on Microsoft NPS. Clients are given vlans based on Network Policies. This WiFi profile is not tunneled to controller but bridged to tagged trunk (2ports lacp) on the switch. AP connects to controller on untagged vlan 111 (L3).
    I'd like to force the switch to assign correct vlan tags to this trunk on which AP is detected. I try to use device-profile for that purpose but without success.
    AP is detected correctly on the switch and assigned device-profile is bound to the trunk. Trk1 receives correct untagged-vlan from the profile.
    If I don't configure tagged-vlan in device profile, none are set on the interface. I was hoping that AP would use vlans dynamically from mvrp depending on the need but nothing like that happens.
    If I do configure tagged-vlan 200-299 in device-profle (we don't use so many vlans but we have reserved this range for future WiFi networks), switch sets them on the trunk BUT omitting all dynamic vlans learnt from mvrp. This is opposite to what I want to achive.
    What am I doing wrong?
    interface Trk1
      untagged vlan 1
      spanning-tree priority 4
      device-type network-device
    exit
    Configuration for device-profile : my-aruba-ap
    untagged-vlan : 111
    tagged-vlan : None (or 200-299)
    cos : None
    speed-duplex : auto
    poe-max-power : Class/LLDP
    allow-jumbo-frames : Disabled
    allow-tunneled-node: Enabled
    profile-mode : client-mode (tried port-mode too)
  • 4.  RE: Using GVRP/MVRP to simplify your network
    Posted Nov 11, 2020 10:37 PM
    Hi PawelZ,
    I'm seeing the same behaviour. It appears that the untagged-vlan defined in the device-profile is able to use a dynamic VLAN discovered using MVRP however tagged VLANs do not use MVRP based dynamic VLANs.
    When I try to specify a larger range of VLANs, than is learned using MVRP, as tagged in the device-profile the MVRP learned VLANs are omitted and the other VLANs that didn't already exist in the VLAN table are created. I noted these VLANs could not be deleted - as they are seen as dynamic by the switch even though their status shows as port-based. They automatically disappear when they are removed from the device-profile configuration.
    Profile-mode should be set to port-mode when assigned to an AP - typically.
    I'm asking to see if this is expected. Have you opened a support case for this?
  • 5.  RE: Using GVRP/MVRP to simplify your network
    Posted Dec 07, 2020 12:08 PM
    as far as i can tell, the VLAN have to be defined, so MVRP could distribute them, and the device-profiles can use them - seems to me that there's no option to create the vlans dynamically and distribute them via mvrp:
    at least:
    vlan 666
       name "Test"
       no ip address
       exit
    device-profile name "default-ap-profile"
       tagged-vlan 666
       exit
    device-profile type "aruba-ap"
       enable
       exit
    Tested with 2530/2540-24G/-48G
    regards
    Peter Bartosch
