Using IAP internal Radius for Authenticating Windows computers and using MAC filtering
  • 1.  Using IAP internal Radius for Authenticating Windows computers and using MAC filtering
    Posted May 17, 2015 05:33 PM
    Hello
    I expect to install about 10 IAPs for used to connect Windows 7 PC and Iphones to the WIFI using IAP VC.
    The plan is to use Radius or LDAP.
    Are their any advantages of using one over the other?
    Can the internal radius be used to authenticate windows machines with Mac filtering or does it have to be an external radius server?
    Thank you in advance
  • 2.  RE: Using IAP internal Radius for Authenticating Windows computers and using MAC filtering
    Posted May 17, 2015 05:35 PM
    I would use a RADIUS server and only allow machine authentication. This is much more secure than using the MAC address.
  • 3.  RE: Using IAP internal Radius for Authenticating Windows computers and using MAC filtering
    Posted May 17, 2015 07:41 PM
    Hi Tim,
    Thanks much for the response.
    Can the internal IAP radius server be integrated into a Windows Networking environment for Machine authentication or would I have to use an external radius server such as windows NAP server etc?
    Thanks again
    Edi
  • 4.  RE: Using IAP internal Radius for Authenticating Windows computers and using MAC filtering
    Posted May 17, 2015 07:54 PM
    You would need something like Microsoft NPS (or ClearPass)
