Education - Australia / New Zealand
last person joined: 8 days ago
A local community of education customers across Australia / NZ. This group will be moderated by HPE Aruba Networking staff and kept up to date with any upcoming training or events that are relevant to the EDU space.
Using IMC to report on running-config status
  • 1.  Using IMC to report on running-config status
    Posted Oct 23, 2016 09:24 AM
    Overview
    For those of you that have Intelligent Management Center (IMC), this may be helpful to ensure that configs are not lost when changes are made, but not saved!
    Automatic checking of configs
    This is the compliance check process I have put together to check if there are any ProCurve devices (anything in the extended ProCurve family that supports the "show run status" command, including the newly branded ArubaOS-Switch) with running config changes not saved - ie not matching the startup config.
    1. Create a Display Command.
      This will execute the command "show run status" on the switch
    2. Create a compliance policy using that display command just created.
    3. Create a Check Task (can be periodic) that runs that compliance policy
      Click on the results to see the detailed list of policy compliance violations
    Automatic Backups in IMC
    You can create system-wide auto-backup of configs.
    • If you select the “backup network wide” checkbox, everything in IMC is included, and you can exclude specific devices.
    • You can reverse this, and set the backups for a defined whitelist only (but then new devices need to be manually added)
    • Filtering is by existing device only (not subnet or similar)
    The Backup History Report (Service > Backup History Report)backup config history.jpg
    • Shows all backup attempts, and details success/failure
    • The list will include all devices being backed up. (If you choose the network-wide backup plan, excluding some devices, then new additional will automatically be added to the backup list)
