last person joined: 5 hours ago
using jQuery (focus text) in header HTML (WEB-LOGIN FORM)
  • 1.  using jQuery (focus text) in header HTML (WEB-LOGIN FORM)
    Posted Oct 06, 2017 01:24 PM
    Hello Gurus
    I´m using a weblogin with access-code (just validate username) I realize that CPPM guest manager support Jquery so I'm trying to use a JQuery code that makes when a textbox lose focus will validate that the content of this element is a correct  (username). This JQuery works as expected in an environment diferent than ClearPass but in CPPM doesnt works.
    The code I am using is as follows:
    $(document).ready(function(){
                    jQuery.fn.extend({
                                   PatronRut: function () {
                                                   // Funciona **works**
                    jQuery.fn.extend({
                                   RutValido: function () {
    // No funciona ***not working**
                    $('#username').focusout(function() {
                                   var error = $('#usernError');
                                   var usernametxtbx = $(this);
                                   var texto = usernametxtbx.val();
                                   if(texto.length > 0 && usernametxtbx.PatronRut() && usernametxtbx.RutValido())
                                                   error.hide();
                                   else{
                                                   error.text('Rut invalido!');
                                                   error.show();
    maybe you can give some TIps.
    Thanks you a lot.
