using ldap errors to inform portal users reason auth faillure
  • 1.  using ldap errors to inform portal users reason auth faillure
    MVP
    Posted Feb 13, 2014 08:29 AM
    So I have a customer where a portal is used to grant access to AD users.
    Their AD has a requirement to change passwords every x time. Problem however is that these users might never connect to the corporate network anymore as the portal is facing out to internet.
    When such a user account has an expired password he cannot log on anymore.
    Access tracker however shows a ietf reply-message with (a code for) the exact reason.
    Is there any way to leverage that ietf reply-message to redirect the user to a different portal where he can set a new password?
    Or in the very least translate that code and return an understandeable error instead of just failing?
  • 2.  RE: using ldap errors to inform portal users reason auth faillure
    Posted Feb 13, 2014 09:32 AM
    In 6.3 for Clearpass, we have introduced an exposed way of checking for account expiration.  Based on this, you can write a policy to redirect based on this value.
  • 3.  RE: using ldap errors to inform portal users reason auth faillure
    MVP
    Posted Feb 13, 2014 09:37 AM
    Details please.
    I'm using AD users and can see the IETF reply-messages.. but how do I turn that into something usefull?
    Since the AD passwd has expired we simply get presented a deny and any role we try pushing gets ignored.
  • 4.  RE: using ldap errors to inform portal users reason auth faillure
    Posted Feb 13, 2014 09:49 AM
    Hmmm...I reread your inquiry.  If the account is ALREADY expired, then it is a reject and I don't believe there is much we can do with that as it's a denial.  However, before the account expires, we can notify the user that it will expire.  Again, this is a new feature, so it's not something I've personally configured (yet)
  • 5.  RE: using ldap errors to inform portal users reason auth faillure
    MVP
    Posted Feb 13, 2014 09:54 AM
    We hjave that running with our the certificates.
    This is a portal that authenticates AD users (not internal guests) so don't think there's an easy way to know when the passwd is going to expire or anything.
    Is there perhaps a way to return an accept even when the account doesn't authenticate?
  • 6.  RE: using ldap errors to inform portal users reason auth faillure
    MVP
    Posted Feb 14, 2014 11:46 AM
    So nobody with any brilliant ideas on how to get this working?
  • 7.  RE: using ldap errors to inform portal users reason auth faillure
    Posted Feb 15, 2014 08:31 AM
    Put a link to the password reset portal on the login page? .......:)
  • 8.  RE: using ldap errors to inform portal users reason auth faillure
    MVP
    Posted Feb 17, 2014 11:05 AM
    Fa from ideal as this portalis also available for guests but seeing as nobody comes up with a brilliant proposal I'm guessing it's pretty much the only option left.
    Has anybody got some more detail;s about this little bit of the 6.3 release notes perhaps:
    - Added the ability to verify whether an Active Directory account has expired. (#15552)
    Seems to be pretty much what I need, or is that only info for accesstracker, not towards the user?
