Using lobby guest by Instant OS, is it possible without Clearpass?
  • 1.  Using lobby guest by Instant OS, is it possible without Clearpass?
    Posted Nov 07, 2016 07:24 AM
    Hi!
    My customer needs for a solution, the IAPs must advertise at least 2 SSID, one for productive network, and the other one for guests, who will have access by a generated code, created by the lobby guest user.
    The question is that, is it possible without Clearpass (or maybe with a controller), or they must be buy Clearpass, to make it work?
    Thanks!
  • 2.  RE: Using lobby guest by Instant OS, is it possible without Clearpass?
    Posted Nov 07, 2016 08:40 AM
    You can do this with username/password without ClearPass. The receptionist would log in to the VC using a special guest provisioning account and create the account.
