I will generate the CSR from the controller. I have installed openssl for windows(gnuwin32). I want to use that as a Certificate authority and generate a certificate for dot1x termination on the controller. How to do it??
This might help you.
http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-can-I-use-OpenSSL-to-create-CA-server-and-public/ta-p/179206
@Vinod, I checked that article. it appears the article is based on openssl on linux.
Please help me on getting a server certificate from openssl installed on windows8. I downloaded and installed gnuwin32 in my PC.
If you do a search for "open ssl windows" there are quite a few articles that say how to do this on Windows:
https://blog.didierstevens.com/2015/03/30/howto-make-your-own-cert-with-openssl-on-windows/
