OK, I figured it out (and I'm no CS-ACS expert by any means). This works on CS-ACS 5.3, YMMV, etc.
In my CS-ACS Access Policies for AirWave, in the applicable Authorization 'rule' under 'Results' was specified 'Permit Access' which is the default Shell Profile. The default Shell Profile cannot be modified. As near as I can tell the Shell Profile 'Permit Access' the only one in use in any rule, in our CS-ACS implementation.
However we also have other Shell Profiles defined (in Policy Element | Authorization and Permissions | Device Administration | Shell Profiles). One of the Shell Profiles is 'Network Operations' (the Shell Profile names roughly correspond to the groups who access devices managed by CS-ACS, but I cannot see anywhere where those are mapped to actual AD Groups. There are also corresponding Network Access Authorization Profiles - exactly the same names as the Shell Profiles - but again I am not sure how one is mapped to these. I am not sure that is needed, read on).
Back to Policy Element | Authorization and Permissions | Device Administration | Shell Profiles: Network Operations. I looked in the "User Guide for Cisco Secure Access Control System 5.2" and searched 'custom' - Chapter 9: Managing Policy Elements on page 9-27 describes how to create a Custom Attribute. I edited the 'Network Operations' shell profile, clicked the Custom Attributes tab, and filled in an Attribute of "role" and made it mandatory, static value, and entered a value of "Admin" (matching the Admin role in AirWave), and saved the change.
I then went back to the Access Policy for AirWave, in which the first rule is for my Network Operations group. In the edit dialog for that rule at the bottom, I changed "Shell Profile" from 'Permit Access' to 'Network Operations' and saved the change.
Voila - AirWave can be accessed with my CS-ACS credentials!
So one can create custom attributes in CS-ACS V5. As soon as you said "post 4.x versions" I was afraid it wouldn't, it does sound awfully RADIUS-ish. But it can be done in V5.x too. Since these custom attributes are probably returned to other TACACS clients, and since 'Admin' is a bit nebulous, I may go back and create an 'AMP-Admin' role in AirWave, the same as 'Admin,' and change CS-ACS to return THAT so it is more obvious what the attribute is for.
Thanks for the response!
