Education - Australia / New Zealand
last person joined: 3 months ago
A local community of education customers across Australia / NZ. This group will be moderated by HPE Aruba Networking staff and kept up to date with any upcoming training or events that are relevant to the EDU space.
Using the "job" command in switches
  • 1.  Using the "job" command in switches
    Posted Oct 31, 2017 09:20 AM
    There is a command in the ProCurve/ArubaOS-Switches that you may not have come across before called "job". It runs a command at a scheduled time or on a countdown.
    2930F-30(config)# job
     JOB-NAME-STR          The name of the job to add or delete.
    2930F-30(config)# job help
    Usage: job <Name> at [HH:]MM [on <Weekday-List>] [config-save] <Command>
           [count <1-1000>]
           job <Name> at [HH:]MM [on [MM/]DD] [config-save] <Command>
           [count <1-1000>]
           job <Name> at <Event> [config-save] <Command>
           job <Name> delay [[DD:]HH:]MM [config-save] <Command> [count <1-1000>]
           job <Name> enable|disable
           no job <Name>
    Description: Schedule a command to run automatically in the future.
                 Jobs can be scheduled to run once, multiple times
                 on a recurring basis, or after certain events.
                 By default, the job is recurring. All commands run with
                 manager privilege in configuration context.
                 The 'no' form of the command deletes a scheduled job.
    This can be useful when making changes that could potentially lock you out. When working on the lab switches, it is a handy fallback to know that the switch will reboot to the previous config if you don't stop the countdown, like the following example.
    2930F-30(config)# job testing delay 3 reboot
    2930F-30(config)# sh job
     Job Scheduler Status and Configuration
      Scheduler Status : Running
                         Event or             Repeat Save
      Name               Time                 Count  Cfg  Command
      testing            Every 00:00:03 min   --     No   reboot
    The switch will reboot after the specified time, loading the previously working config without any of the recent changes.
    Once your testing has completed successfully, you can remove the job:
    2930F-30(config)# no job testing
    It is not quite the same as the checkpoint feature in the new 8400/8320 switches, but it can be a useful tool all the same.
