Wired Intelligent Edge
Using user-roles on ports with phone and PC connected
  • 1.  Using user-roles on ports with phone and PC connected
    Posted Jun 10, 2020 11:58 AM
    Hi All,
    I'm looking at the possibility to use user-roles within some of our head office / depot switches, we already use these extensively within our store environment however the setup in stores is a little different.
    Whilst most of my user roles work fine I'm having some trouble on ports that have both a standard Windows PC attached and also a Mitel IP phone, in these circumstances we use a single data outlet with the PC attached to the thru port on the phone.
    This setup works fine when user-roles are not enabled, with the data VLAN being untagged and the voice VLAN tagged as below and each device completing a successful 802.1x authentication.
    interface 1/1
    name "Authenticated Port"
    tagged vlan 8
    untagged vlan 101
    aaa port-access authenticator
    aaa port-access authenticator client-limit 4
    aaa port-access mac-based
    aaa port-access controlled-direction in
    aaa port-access auth-order mac-based authenticator
    aaa port-access auth-priority authenticator mac-based
    spanning-tree admin-edge-port
    spanning-tree root-guard bpdu-protection
    However, when I enable user-roles I get the following error message and one of the devices ends up in the denyall role.
    I 06/10/20 16:50:41 00560 ports: ST2-CMDR: port 1/1 PD Detected.
    I 06/10/20 16:50:41 00561 ports: ST2-CMDR: port 1/1 Applying Power to PD.
    I 06/10/20 16:50:44 00435 ports: ST2-CMDR: port 1/1 is Blocked by AAA
    I 06/10/20 16:50:44 00435 ports: ST2-CMDR: port 1/1 is Blocked by STP
    I 06/10/20 16:50:44 00076 ports: ST2-CMDR: port 1/1 is now on-line
    W 06/10/20 16:51:15 05800 dca: ST2-CMDR: Failed to apply user role
    'ROLE-PHONE-WIRED' to 8021X client 08000F3985EC on port 1/1: device
    attribute is already applied on this port.
    I've also tried amending the logic in CPPM to return the same role for each device to no avail.
    Essentially I guess my question is how do I configure a user-role to permit both devices as long as they are authenticated on the same port - is this even possible, I presume it must be as this isn't exactly an uncommon setup.
    Thanks in advance,
    Matt.
  • 2.  RE: Using user-roles on ports with phone and PC connected
    Posted Jun 10, 2020 12:11 PM
    Are you planning to do 802.1X authentication for the Windows Machine ? or just Mac Auth ?
    Sent from Mail for Windows 10
  • 3.  RE: Using user-roles on ports with phone and PC connected
    Posted Jun 10, 2020 12:13 PM
    You should you use two different user-roles
    aaa authorization user-role name "VOIP-ROLE"
    policy "ALLOW-ALL-POLICY"
    reauth-period 86400
    vlan-name-tagged "VoIP"
    exit
    aaa authorization user-role name "MACHINE-AUTH-ROLE"
    reauth-period 86400
    vlan-name "DATA"
    exit
  • 4.  RE: Using user-roles on ports with phone and PC connected
    Posted Jun 10, 2020 03:48 PM
    Thanks Victor, I've put it back to two separate roles and removed this part...
    device
     admin-edge-port
    Please to report it's working fine now
    Port Access Client Status
    Port Client Name MAC Address IP Address User Role Type VLAN
    1/1 host/D016W... 0023ae-68c787 10.244.232.139 ROLE-COMPUTERI... 8021X 101
    1/1 MGTDJDP.16 08000f-3985ec 10.244.230.29 ROLE-PHONE-WIRED 8021X 8
    Thanks for all your help and your quick response.
    Matt.
