I made the jump to HP and boy did I not expect it to be so different from cisco. I have a very basic Metro -E on a router install I need to set up. The voice vlan is 100, the data vlan is 1. this is the setup on the cisco end.
On the 2811-
interface FastEthernet0/0
description LAN Interface
no ip address
duplex auto
speed auto
end
cisco2811#sh run int fa0/0.10
interface FastEthernet0/0.10
description Data Network
encapsulation dot1Q 10
ip address 10.231.3.1 255.255.255.0
ip helper-address 10.231.1.6
end
cisco2811#sh run int fa0/0.100
interface FastEthernet0/0.100
description Voice Network
encapsulation dot1Q 100
ip address 10.231.30.1 255.255.255.0
end
My questions -
1) How do I pass vlans (cisco calls it a trunk) on this HP?
Specifics given the cisco stuff above would be great. I figure I take port 25 and tag vlan 1 and 100 on it. and leave the main switchports untagged for vlan 1 and tagged for 100 (voice?) Whats tripping me up is that 1 vlan must be untagged? Should I untag 1 or 100 on port 25?
2) Do I need to tag the voice vlan (100) on the main non trunk switch ports or let the QOS-> Voice VLAN setup auto tag them?
I attached as much config info as possible, any help would be amazing.
#1905v.VOIP#vlans#cisco
