Hi guys,
I would like to know if the V1910 is capable of denying access from a given vlan and into other vlans on the switch?
I need vlan40 to be for guest only and they should only be allowed to travel through the network and go on the internet.
Can some show me the commands to accomplish this?
I've tried the following commands with no luck at all:
acl number 3001
rule 0 deny ip source 10.203.40.0 0 destination 10.203.10.0 0
traffic classifier vlan40_2_vlan10
if-match acl 3001
traffic behavior deny_stats_2
filter deny
qos policy vlan40_acl_vlan10
classifier vlan40_2_vlan10 behavior deny_stats_2
qos vlan-policy vlan40_acl_vlan10 vlan 10 inbound
See my configuration on my switch:
version 5.20, Release 1513P85
sysname HP
dhcp relay server-group 1 ip 10.203.10.11
domain default enable system
undo ipv6
telnet server enable
ip ttl-expires enable
password-recovery enable
acl number 3001
vlan 1
vlan 10
description Server
name VLAN_10
vlan 20
description Clients
name VLAN_20
vlan 30
description Clients_Wifi
name VLAN_30
vlan 40
name VLAN_40
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
traffic classifier vlan40_2_vlan10 operator and
if-match acl 3001
filter deny
user-group system
local-user admin
authorization-attribute level 3
service-type ssh telnet terminal
service-type web
stp mode rstp
stp enable
interface Bridge-Aggregation1
description LACP_link_to_SYNOLOGY
port link-type trunk
undo port trunk permit vlan 1
port trunk permit vlan 10
port trunk pvid vlan 10
link-aggregation mode dynamic
interface NULL0
interface Vlan-interface1
ip address 10.203.5.2 255.255.255.0
interface Vlan-interface10
ip address 10.203.10.1 255.255.255.0
dhcp select relay
dhcp relay server-select 1
interface Vlan-interface20
ip address 10.203.20.1 255.255.255.0
dhcp select relay
interface Vlan-interface30
ip address 10.203.30.1 255.255.255.0
dhcp select relay
interface Vlan-interface40
ip address 10.203.40.1 255.255.255.0
dhcp select relay
interface GigabitEthernet1/0/1
stp edged-port enable
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
port access vlan 10
interface GigabitEthernet1/0/4
port access vlan 10
interface GigabitEthernet1/0/5
port access vlan 10
interface GigabitEthernet1/0/6
port access vlan 10
interface GigabitEthernet1/0/7
port access vlan 10
interface GigabitEthernet1/0/8
port access vlan 10
interface GigabitEthernet1/0/9
port access vlan 10
interface GigabitEthernet1/0/10
port access vlan 10
interface GigabitEthernet1/0/11
port access vlan 10
interface GigabitEthernet1/0/12
port access vlan 10
interface GigabitEthernet1/0/13
port access vlan 10
interface GigabitEthernet1/0/14
port access vlan 10
interface GigabitEthernet1/0/15
port access vlan 10
interface GigabitEthernet1/0/16
port access vlan 10
interface GigabitEthernet1/0/17
port access vlan 10
interface GigabitEthernet1/0/18
port access vlan 10
interface GigabitEthernet1/0/19
port access vlan 10
interface GigabitEthernet1/0/20
port access vlan 10
interface GigabitEthernet1/0/21
port access vlan 10
interface GigabitEthernet1/0/22
port access vlan 10
interface GigabitEthernet1/0/23
port access vlan 10
interface GigabitEthernet1/0/24
port access vlan 10
interface GigabitEthernet1/0/25
port access vlan 10
interface GigabitEthernet1/0/26
port access vlan 10
interface GigabitEthernet1/0/27
port access vlan 10
interface GigabitEthernet1/0/28
port access vlan 10
interface GigabitEthernet1/0/29
port access vlan 10
interface GigabitEthernet1/0/30
port access vlan 10
interface GigabitEthernet1/0/31
port access vlan 10
interface GigabitEthernet1/0/32
port access vlan 10
interface GigabitEthernet1/0/33
port access vlan 10
interface GigabitEthernet1/0/34
port access vlan 10
interface GigabitEthernet1/0/35
port access vlan 10
interface GigabitEthernet1/0/36
port access vlan 10
interface GigabitEthernet1/0/37
port access vlan 10
interface GigabitEthernet1/0/38
port access vlan 10
interface GigabitEthernet1/0/39
port access vlan 10
interface GigabitEthernet1/0/40
port access vlan 10
interface GigabitEthernet1/0/41
port access vlan 10
interface GigabitEthernet1/0/42
port access vlan 10
interface GigabitEthernet1/0/43
port access vlan 10
interface GigabitEthernet1/0/44
port access vlan 10
interface GigabitEthernet1/0/45
link-aggregation port-priority 100
port link-aggregation group 1
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
port access vlan 10
interface GigabitEthernet1/0/48
port access vlan 10
interface GigabitEthernet1/0/49
port link-type hybrid
port hybrid vlan 10 20 30 40 tagged
port hybrid vlan 1 untagged
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
ip route-static 0.0.0.0 0.0.0.0 Vlan-interface1 10.203.5.1
snmp-agent
snmp-agent local-engineid 8000000B03CC3E5FE426FA
snmp-agent sys-info contact motz
snmp-agent sys-info location serverroom
snmp-agent sys-info version v3
dhcp enable
ssh server enable
user-interface aux 0
authentication-mode scheme
user-interface vty 0 15
return
P.S. This thread has been moved from Comware-Based to Web & Unmanaged. - Hp forum moderator
#VLAN#v1910#ACL#routing
