Comware
V1910-48G - LACP on SFP ports not working
  • 1.  V1910-48G - LACP on SFP ports not working
    Posted Jun 05, 2014 04:54 PM
    Hi guys,
    I'm new here so please bare with me :o)
    I just got 2 HP V1910 switches and I want to make a LAG (LACP) between them. I brought 4 HP X121 LC SX Transceivers and got som OM3 fiber panels mounted on each site. If I connect 1 cable and make a single connection between the switches everything works like a charm and the switches exchange data with each other.
    I've have been trying to make a LACP (dynamic) configuration on the switches to boost the uplink between them but when I type in my last command the CLI just throws an error and I can't get the LAG/Trunk online.
    SW1 already got a LACP dynamic trunk configured just using 2 ethernet ports and they are connected to a Synolygy DS-412+. This configuration works just fine and I have used the commands from the configuration to try and make a configuration on the SFP ports.
    See my commands:
    interface Bridge-Aggregation 2
    description LACP_link_to_HPSKUNK
    link-aggregation mode dynamic
    quit
    interface g1/0/49
    port link-aggregation group 2
    quit
    interface g1/0/50
    quit
    port link-type trunk <--- This commands fails and just tells that the configuration couldn't complete (The specific error isn't available right now as the switches are run i production and when I play around with them the link goes down...)
    So my questions are:
    Can the V1910 do a LACP Dynamic on the SFP ports?
    Can the V1910 do a LACP Static on the SFP ports?
    Can I in some way make both switches use my 2 fiber connections to boost the uplink between them?
    Should the type of my SFP ports be access instead?
    I hope some of you guys can point me in the right direction regarding my issue with the switches.
    I've 5 vlans: 1,10,20,30,40. They are working just fine, my networks can communicate with each other and travel across the switches without issues.
    The config for both switches comes her:
    ###SW1###
    version 5.20, Release 1513P85
    sysname HP-V1910-Skunk
    domain default enable system
    telnet server enable
    ip ttl-expires enable
    password-recovery enable
    vlan 1
    description Management
    vlan 10
    description Server
    vlan 20
    description Client
    vlan 30
    description WIFI
    vlan 40
    description WIFI-GUEST
    domain system
    access-limit disable
    state active
    idle-cut disable
    self-service-url disable
    user-group system
    local-user admin
    authorization-attribute level 3
    service-type ssh telnet terminal
    service-type web
    stp mode rstp
    stp enable
    interface NULL0
    interface Vlan-interface1
    ip address 10.203.5.3 255.255.255.0
    interface GigabitEthernet1/0/1
    port link-type hybrid
    port hybrid vlan 1 untagged
    stp edged-port enable
    interface GigabitEthernet1/0/2
    interface GigabitEthernet1/0/3
    interface GigabitEthernet1/0/4
    interface GigabitEthernet1/0/5
    interface GigabitEthernet1/0/6
    interface GigabitEthernet1/0/7
    interface GigabitEthernet1/0/8
    undo port hybrid vlan 1
    port hybrid vlan 10 untagged
    interface GigabitEthernet1/0/9
    interface GigabitEthernet1/0/10
    interface GigabitEthernet1/0/11
    interface GigabitEthernet1/0/12
    interface GigabitEthernet1/0/13
    interface GigabitEthernet1/0/14
    port hybrid vlan 20 untagged
    port hybrid pvid vlan 20
    interface GigabitEthernet1/0/15
    interface GigabitEthernet1/0/16
    interface GigabitEthernet1/0/17
    interface GigabitEthernet1/0/18
    interface GigabitEthernet1/0/19
    interface GigabitEthernet1/0/20
    interface GigabitEthernet1/0/21
    interface GigabitEthernet1/0/22
    interface GigabitEthernet1/0/23
    interface GigabitEthernet1/0/24
    interface GigabitEthernet1/0/25
    interface GigabitEthernet1/0/26
    interface GigabitEthernet1/0/27
    interface GigabitEthernet1/0/28
    interface GigabitEthernet1/0/29
    interface GigabitEthernet1/0/30
    interface GigabitEthernet1/0/31
    interface GigabitEthernet1/0/32
    interface GigabitEthernet1/0/33
    interface GigabitEthernet1/0/34
    interface GigabitEthernet1/0/35
    interface GigabitEthernet1/0/36
    interface GigabitEthernet1/0/37
    interface GigabitEthernet1/0/38
    interface GigabitEthernet1/0/39
    interface GigabitEthernet1/0/40
    interface GigabitEthernet1/0/41
    interface GigabitEthernet1/0/42
    interface GigabitEthernet1/0/43
    interface GigabitEthernet1/0/44
    interface GigabitEthernet1/0/45
    interface GigabitEthernet1/0/46
    interface GigabitEthernet1/0/47
    interface GigabitEthernet1/0/48
    interface GigabitEthernet1/0/49
    port hybrid vlan 10 20 30 40 tagged
    interface GigabitEthernet1/0/50
    interface GigabitEthernet1/0/51
    interface GigabitEthernet1/0/52
    ip route-static 0.0.0.0 0.0.0.0 Vlan-interface1 10.203.5.2
    snmp-agent
    snmp-agent local-engineid 8000000B03CC3E5FE3F6F2
    snmp-agent sys-info contact motz
    snmp-agent sys-info location skunk
    snmp-agent sys-info version v3
    dhcp enable
    ssh server enable
    user-interface aux 0
    authentication-mode scheme
    user-interface vty 0 15
    return
    ###SW2###
    sysname HP
    dhcp relay server-group 1 ip 10.203.10.11
    undo ipv6
    acl number 3001
    rule 0 deny ip source 10.203.40.0 0 destination 10.203.10.0 0
    vlan 1
    vlan 10
    description Server
    name VLAN_10
    vlan 20
    description Clients
    name VLAN_20
    vlan 30
    description Clients_Wifi
    name VLAN_30
    vlan 40
    name VLAN_40
    domain system
    state active
    idle-cut disable
    traffic classifier vlan40_2_vlan10 operator and
    if-match acl 3001
    traffic behavior deny_stats_2
    filter deny
    qos policy vlan40_acl_vlan10
    classifier vlan40_2_vlan10 behavior deny_stats_2
    user-group system
    local-user admin
    service-type web
    stp mode rstp
    stp enable
    interface Bridge-Aggregation1
    description LACP_link_to_SYNOLOGY
    undo port trunk permit vlan 1
    port trunk permit vlan 10
    port trunk pvid vlan 10
    interface NULL0
    ip address 10.203.5.2 255.255.255.0
    interface Vlan-interface10
    ip address 10.203.10.1 255.255.255.0
    dhcp select relay
    dhcp relay server-select 1
    interface Vlan-interface20
    ip address 10.203.20.1 255.255.255.0
    dhcp select relay
    interface Vlan-interface30
    ip address 10.203.30.1 255.255.255.0
    dhcp select relay
    interface Vlan-interface40
    ip address 10.203.40.1 255.255.255.0
    dhcp select relay
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    port access vlan 10
    link-aggregation port-priority 100
    port link-aggregation group 1
    port access vlan 10
    port access vlan 10
    ip route-static 0.0.0.0 0.0.0.0 Vlan-interface1 10.203.5.1
    snmp-agent
    snmp-agent local-engineid 8000000B03CC3E5FE426FA
    snmp-agent sys-info location serverroom
    dhcp enable
    ssh server enable
    qos vlan-policy vlan40_acl_vlan10 vlan 10 inbound
    return
    P.S. This thread has been moevd from Comware-Based to Web & Unmanaged. - Hp forum moderator
    #v1910
    #LAG
    #fiber
    #LACP
    #SFP
  • 2.  RE: V1910-48G - LACP on SFP ports not working
    Posted Jun 09, 2014 05:31 AM
    Hi guys,
    I did solve my problems regarding LACP on the SFP ports. I found some insight from this post: Link
    I found out that I already did assign the ports by them self to Hybrid but was trying to make the LACP as a Trunk. The ports and the LACP group has to be the same type if not the LACP group will not come up and the error doesn't give you any clues.
    I used the following commands:
    description LACP_link_1
    quit
    interface g1/0/49
    port link-type access
    link-aggregation port-priority 50
    quit
    interface g1/0/50
    quit
    port hybrid pvid vlan 1
    quit
    Hope that this can help outers out there if they are facing the same problems as I was :o)
    #LAG
    #SFP
    #LACP
    #v1910
