Comware
  • 1.  v1910 - how to fixed mac address to a single port
    Posted Mar 23, 2012 05:04 AM
    hi,
    i have read through the whole manual yet cannot find how to fixed mac address on a single port. What we would like to do is, to fixed mac address on a port, allowing only device with the fixed mac address to access and reject the rest.
    please advise, thanks
    wrobot
  • 2.  RE: v1910 - how to fixed mac address to a single port
    Posted Apr 12, 2012 10:31 AM
    I have exactly the same problem.
    I tried to set an MAC based ACL to filter traffic,but no luck.
    can ANYONE from HP please advise if this is even possible and if yes - how to set an MAC-based ACL
    to permit/deny traffic - the 1910 documentation just sucks as there's no examples or explanations.
    for instance:
    let's have ACL 4000 [link setup] with rule id 1 which should deny any traffic from source MAC 0000-1111-2222.
    [took me some time to figure out what ' format of MAC address is "H-H-H" ' really means - no example of the correct syntax at all.]
    so I specified source MAC and now - what is the source mask ?
    source mask of WHAT? is this a source MAC mask? or subnet mask ?
  • 3.  RE: v1910 - how to fixed mac address to a single port
    Posted Apr 16, 2012 09:00 AM
    On a HP V1910 switch this is how you do MAC filtering:
     go to 'Network > MAC > Add'
    Type in the MAC address of the PC you want secured, choose ‘Static’,' VLAN1', select port the PC is connected to.
    Next go to ‘Authentication > 802.1x and enable 802.1x, then click 'Add'.
    Then select the port that has the static MAC address on, select 'MAC Based port control',' Auto Authorization',
    and click 'Apply'.
    This should then secure the port so it only works with the single static MAC address.
    enjoy.
    #fixedmacaddress
  • 4.  RE: v1910 - how to fixed mac address to a single port
    Posted Sep 06, 2012 08:45 AM
    What about multiple ports ?
    I manage a lot of switches v1910 connected to a lot of fixed computers. Using mac address authentication, shall i configure each port one by one ? I am scared !
    Thanks for helping
    #macaddressfixv1910
    #fix
    #Mac
    #v1910
    #address
  • 5.  RE: v1910 - how to fixed mac address to a single port
    Posted Sep 06, 2012 09:06 AM
    How to authorize automatically the learned mac addresses in a v1910 switch ?
    Please help, hackers threaten us !
  • 6.  RE: v1910 - how to fixed mac address to a single port
    Posted Jan 04, 2013 04:54 AM
    RooRoo thanks for your reply that helped a lot!! 3com has diffrent logic...
  • 7.  RE: v1910 - how to fixed mac address to a single port
    Posted Jul 14, 2015 07:44 AM
    I need a Switch that can  Specify up to multiple MAC  addresses on 1 port
