Wired
Validate Trunking between switches?
  • 1.  Validate Trunking between switches?
    Posted Feb 10, 2021 07:30 PM
    Hi All,
    Can someone help me? I am new to HPE/Aruba switches and need to know some shortcuts :)
    So how can I tell there is a trunk between my 1 gig and ten gig switches? All are HPE/Aruba. Last time I was at Data Center, I saw almost all ports are populated.
    There is a "sync or stacking" cable between two 10g switches (Labeled DMZ), and 4 more 10g (labeled DB). What is the cable actually called?
    There are six 1 Gig switches and there is a sync/stacking cable between one group of three (DMZ) and the other group three (DB).
    How can I confirm they are connected to each other without being onsite? I have remote access and have been using the web interface. Can you please tell me an easy way from the cli how to validate I have a trunk between 10g and 1g switches that are carrying the same vlans?
    I have six of these.
    HPE FF 5700-32XGT-8XG-2QSFP+ Switch JG898A
    and 6 of these
    HP A5500-24G-4SFP HI
    Thanks for your help!
    Jerry Roy
  • 2.  RE: Validate Trunking between switches?
    MVP GURU
    Posted Feb 14, 2021 05:48 AM
    Hi Jerry! you should post your doubts/requests/issues on the Airheads Wired Intelligent Edge sub-forum otherwise you're at risk that your post get unnoticed here in this part of the forum (don't ask me why).
    Davide Poletto
  • 3.  RE: Validate Trunking between switches?
    Posted Feb 16, 2021 12:02 PM
    Hi David,
    Thanks for the info, I will do what you suggested, it is greatly appreciated.
    Jerry
    Jerry Roy, Sr. Network Engineer
    BirchStreet Systems
    949-567-7055  |  cell 562-305-9545 | jroy@birchstreet.net
    www.birchstreet.net  |   Blog  |  twitter  |  facebook  |  LinkedIn
