Yes you bet. I have been online with 9-of-10 AP's. VC has a DHCP network assigned IP. My 10th AP, the last one installed 2 weeks after the inital install never did show up on the VC. Prior to the firmware upgrade the system seemed to be working well and correctly. In fact, when i logged into the VC gui- the column that lists your AP's, listed my VC in that list too. That way, obviously, I can click on it for device details. Im not sure why the 10th AP never did appear in that list, autojoin enabled.
yesterday I did a firmware upgrade. It said that it was successful, rebooted all machines. When they rebooted, I had to turn them all off again, turn on the VC that was the VC before, first. Then I turned on all the rest. The 10th AP still is not listed and the VC AP is not listed. However, I know that I am logged into it because it shows its' name at the top.
I just wasn't sure if the firware upgrade had anything to do with this. Seems to me that it should still be listed there. I never changed the VLAN's but I can go check that. Have to figure out how. I suppose I have to console into the 10th AP since it is not listed in the GUI. The VC can obviously see 8 of the AP's as they are in the list.
