VC reaction to an AirWave unavailability
  • 1.  VC reaction to an AirWave unavailability
    Posted Mar 30, 2016 06:04 AM
    We have several IAP-205-RW entirely managed with AirWave. We would like to understand what happen precisely if the AirWave server becomes unavailable. Especially, how many minutes after a failure of the AirWave server does it take for the IAP to be manageable again from the VC ?
    I have found the following information on the forum :
    "By design, IAPs send packet updates regularly to AirWave over HTTPS not SNMP.  This moves the information exchange from a request based exchange to an announcement style where the IAP gives updates at 5 minute intervals (with 1 minute check up heartbeats)."
    Sourcehttp://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/Blinking-IAPs-in-Airwave/td-p/149716
    My main question is : Is it possible to customize these parameters, or are they dependent from the OS ?
    Moreover, we have run a few tests on our lab by closing the HTTPS communication port between a VC and AirWave (in order to simulate a failure of the AirWave server from the point of view of the VC).
    After 5 minutes on the VC, a show log system gives :
    => Remove temp state file for Airwave
    Then, each minute :
    => awc_connect to X.X.X.X
    => Failed to connect to X.X.X.X
    This is very coherent with the explanation above.
    However, on the VC, it takes up to 5 more minutes for the AirWave state to be changed to "Disconnected". So we can manage the IAP from the VC "only" 10 minutes after a failure of the AirWave server, which is the double of what was expected. Could you please help me to understand what happen during this time gap ? Just in case it increases...
    Thank you very much for your help. I can provide you with more information or logs if needed.
