Network Management
VC showing Mismatched on Airwave
This thread has been viewed 22 times
  • 1.  VC showing Mismatched on Airwave
    Posted Feb 21, 2019 11:41 AM
    Hi.
    I installed an AMP server to manage two IAP cluster. I configured the first VC with SNMP community and Airwave options. It appeared at airwave and then I moved to the correct folder and group.
    The APs are showing 'Good', but the VC is showing 'Mismatched'.
    I tried:
    - Remove and insert again
    - Fetch the VC template from the VC
    - Delete the VC template
    - Move the VC to a different group of the IAPs.
    None had worked.
    Someone knows how to fix this?
    AMP Version: 8.2.8.1
  • 2.  RE: VC showing Mismatched on Airwave
    Posted Feb 21, 2019 09:34 PM
    Could we click on the mismatch and check what exactly is the mismatched config?
  • 3.  RE: VC showing Mismatched on Airwave
    Posted Feb 22, 2019 12:04 PM
    Hi, see below the output:
    allow-new-aps
    ams-ip xxx.xx.10.24
    ams-key XXXXXXXXXX
    auth-failure-blacklist-time 3600
    auth-survivability cache-time-out 24
    blacklist-time 3600
    clock summer-time BRAD recurring first sunday november 00:00 last sunday february 00:00
    clock timezone Brasilia -03 00
    Actual cp-cert-checksum 5c1ac28bde8ff4e904c39dabae240044
    dpi
    dynamic-radius-proxy
    dynamic-tacacs-proxy
    enet-vlan 80
    enet0-port-profile default_wired_port_profile
    extended-ssid
    hash-mgmt-password
    hash-mgmt-user admin password XXXXXXXXXX 350a450c0298281a590809ebe8037f3d04fe15389183505930ae8c1b7b06b0c499a79b3fce
    ip-mode v4-prefer
    name "Aruba01"
    ntp-server 200.160.7.186
    organization "mycompany:IAPs"
    report-rssi-to-central unassociated-and-associated-clients
    rf-band all
    snmp-server community XXXXXXXXXX
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    terminal-access
    time-range Expediente periodic monday 08:00 to friday 19:00
    virtual-controller-country BR
    virtual-controller-ip xxx.xx.80.99
    virtual-controller-key XXXXXXXXXX
    wlan access-rule Guest"
    rule any any match any any any permit
    wlan access-rule "default_wired_port_profile"
    wlan access-rule "guest"
    wlan access-rule "guest-login"
    captive-portal external profile Clearpass
    rule any any match udp 53 53 permit
    rule any any match udp 67 68 permit
    rule any any match udp 67 69 permit
    rule xxx.xx.80.63 255.255.255.255 match tcp 80 80 permit
    rule xxx.xx.80.63 255.255.255.255 match tcp 443 443 permit
    rule any any match any any any deny
    airgroup
    disable
    airgroupservice "DLNA Media"
    disable
    airgroupservice "DLNA Print"
    disable
    airgroupservice AmazonTV
    disable
    airgroupservice DIAL
    disable
    airgroupservice airplay
    description AirPlay
    disable
    airgroupservice airprint
    description AirPrint
    disable
    airgroupservice allowall
    disable
    airgroupservice chat
    disable
    airgroupservice googlecast
    disable
    airgroupservice itunes
    disable
    airgroupservice remotemgmt
    disable
    airgroupservice sharing
    disable
    arm
    80mhz-support
    air-time-fairness-mode default-access
    band-steering-mode prefer-5ghz
    client-aware
    max-tx-power 127
    min-tx-power 18
    scanning
    wide-bands 5ghz
    wlan auth-server AS1_#guest#_
    acctport 1813
    ip nae1.cloudguest.central.arubanetworks.com
    nas-id c244a1ab-48e1-4970-a8fe-a87e4e3d9943
    port 1812
    radsec
    rfc3576
    timeout 20
    wlan auth-server AS2_#guest#_
    acctport 1813
    ip nae1-elb.cloudguest.central.arubanetworks.com
    port 1812
    radsec port 443
    rfc3576
    timeout 20
    wlan auth-server ClearPass
    acctport 1813
    cppm-rfc3576-port 5999
    ip xxx.xx.80.63
    key XXXXXXXXXX
    nas-id xxx.xx.80.99
    nas-ip xx.xx.80.99
    port 1812
    rfc3576
    rfc5997
    service-type-framed-user 1x
    service-type-framed-user cp
    service-type-framed-user mac
    wlan captive-portal
    background-color 16777215
    banner-color 15329769
    banner-text "57;65;6c;63;6f;6d;65;20;74;6f;20;47;75;65;73;74;20;4e;65;74;77;6f;72;6b;"
    decoded-texts "banner/terms/policy"
    terms-of-use "54;68;69;73;20;6e;65;74;77;6f;72;6b;20;69;73;20;6e;6f;74;20;73;65;63;75;72;65;20;61;6e;64;20;75;73;65;20;69;74;20;61;74;20;79;6f;75;72;20;6f;77;6e;20;72;69;73;6b;2e;"
    use-policy "50;6c;65;61;73;65;20;72;65;61;64;20;61;6e;64;20;61;63;63;65;70;74;20;74;65;72;6d;73;20;61;6e;64;20;63;6f;6e;64;69;74;69;6f;6e;73;20;61;6e;64;20;74;68;65;6e;20;6c;6f;67;69;6e;2e;"
    clarity
    inline-auth-stats
    inline-dhcp-stats
    inline-dns-stats
    inline-sta-stats
    wlan external-captive-portal
    auth-text "Authenticated"
    auto-whitelist-disable
    https
    port 80
    server "localhost"
    url "/"
    wlan external-captive-portal Clearpass
    auth-text ""
    https
    port 443
    server "XXX.XX.80.63"
    url "/guest/guest.php"
    ids
    wireless-containment none
    uplink
    enforce none
    failover-internet-pkt-lost-cnt 10
    failover-internet-pkt-send-freq 30
    failover-vpn-timeout 180
    preemption
    wired-port-profile default_wired_port_profile
    access-rule-name default_wired_port_profile
    allowed-vlan all
    captive-portal disable
    no dot1x
    duplex full
    native-vlan 1
    no poe
    shutdown
    speed auto
    switchport-mode trunk
    type employee
    wlan ssid-profile Guest"
    auth-server InternalServer
    broadcast-filter arp
    dmo-channel-utilization-threshold 90
    dtim-period 1
    enable
    essid Guest"
    local-probe-req-thresh 0
    max-authentication-failures 0
    max-clients-threshold 64
    opmode wpa2-psk-aes
    rf-band all
    time-range Expediente enable
    type employee
    vlan 900
    wpa-passphrase XXXXXXXXXX
  • 4.  RE: VC showing Mismatched on Airwave
    Posted Feb 24, 2019 09:29 PM
    I dont see any actual or desired showing up in the output. What is the version of the device?
    Also, could you try an import setting from device manage page on Airwave?
  • 5.  RE: VC showing Mismatched on Airwave
    Posted Feb 25, 2019 09:02 AM
    The IAP cluster is with the version 6.5.4.8
    AMP is 8.2.8.1
    I tried to import in Groups -> List -> My_IAP_Group -> Templates -> Aruba Instant Virtual Controler -> pencil(edit) -> Template Select -> Fetch Template from device -> Fetch -> save -> Save and Apply -> Apply Changes Now
    Its changes the status to 'Verifying' and after some minutes shows again 'Mismatched'
  • 6.  RE: VC showing Mismatched on Airwave
    Posted Feb 25, 2019 10:48 AM
    Not the template fetch. Go to VC manage page on Airwave and you will see import setting towards the end of the page. You can hit on that. If it is still showing mismatch it would be good to open a TAC case as you might have to put it in manage mode once to sync and back to monitor(i will suggest doing it along with TAC after verifying config).
  • 7.  RE: VC showing Mismatched on Airwave
    Posted Feb 25, 2019 11:10 AM
    Not worked... but thank you. I will open a TAC case. Ty.
