I had already configured the controller for 3x10G, and How to verify that the port-channel are using 30G bw? on the controller side.
What kind of Link Aggregation are you using?
What is your configuration?
What is the switch manufacturer an what commands are you using for link aggregation?
Hi cjoseph
LACP
Mode Active
Cisco Switch (switchport mode trunk, port-channel group 0, port-channel protocol lacp)
Please see the tutorial here: http://community.arubanetworks.com/t5/Mobility-Hero-Tutorials/Link-Aggregation-LACP-on-Aruba-Controller-Jan-2014/ta-p/143679
Thanks, I'd already read this topic, and How to show BW like this on the controller? (Capture from command of cisco switch)
Ex : "BW 3000000 Kbit"
There is no command that shows you the bandwidth. The show interface port channel command does tell you what interfaces are bonded, however... http://www.arubanetworks.com/techdocs/ArubaOS_65x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/show_interface_port_chan.htm?Highlight=show interface
