When running this command - I exported into excel and sorted by MAC address and/or by IP address.
Oddly I see similar MAC addresses (possibly MAC randomization) across multiple SSIDs with the same IP.
Of course, this cannot be an accurate list of connected devices if it shows the same device on multiple SSIDs.
I am looking for a client that connects to an SSID and show that encryption method. I don't think I'm getting that output with this command.
This is just a sampling, showing the first two IP addresses, but this continues for all devices using TKIP.
Also, I've taken a sampling of 20 IP addresses and immediately did a "show user-table ip x.x.x.x" and shows nothing. Also, tried "| include". I've also done this on the master controller GUI, all WLAN clients (6.5.4.x) and do not see a client with these IP addresses.
Any advice?
macs and ip's have been changed to protect the innocent.
ee:a0:7f:1e:29:33 10.10.97.20 PSKSSID AP ee:a0:7f:c9:e2:92 default 810 WPA-PSK-TKIP 0 FORWARD_TUNNEL_80211 PSKSSID-aaa_prof/PSKSSID-dot1x_prof
ee:a0:7f:1e:29:31 10.10.97.20 SSID-A AP ee:a0:7f:c9:e2:92 default 94 WPA-TKIP 0 FORWARD_TUNNEL_80211 SSID-A-aaa_prof/SSID-A-dot1x_prof
ee:a0:7f:1e:29:30 10.10.97.20 SSID-X AP ee:a0:7f:c9:e2:92 default 84 WPA-TKIP 0 FORWARD_TUNNEL_80211 SSID-X-aaa_prof/SSID-X-dot1x_prof
ee:a0:7f:1e:29:23 10.10.97.20 PSKSSID AP ee:a0:7f:c9:e2:92 default 810 WPA-PSK-TKIP 2 FORWARD_TUNNEL_80211 PSKSSID-aaa_prof/PSKSSID-dot1x_prof
ee:a0:7f:1e:29:21 10.10.97.20 SSID-A AP ee:a0:7f:c9:e2:92 default 94 WPA-TKIP 0 FORWARD_TUNNEL_80211 SSID-A-aaa_prof/SSID-A-dot1x_prof
ee:a0:7f:1e:29:20 10.10.97.20 SSID-X AP ee:a0:7f:c9:e2:92 default 84 WPA-TKIP 0 FORWARD_TUNNEL_80211 SSID-X-aaa_prof/SSID-X-dot1x_prof
ee:a0:7f:1e:26:93 10.10.163.35 PSKSSID AP ee:a0:7f:c9:e2:68 default 810 WPA-PSK-TKIP 1 FORWARD_TUNNEL_80211 PSKSSID-aaa_prof/PSKSSID-dot1x_prof
ee:a0:7f:1e:26:91 10.10.163.35 SSID-A AP ee:a0:7f:c9:e2:68 default 94 WPA-TKIP 0 FORWARD_TUNNEL_80211 SSID-A-aaa_prof/SSID-A-dot1x_prof
ee:a0:7f:1e:26:90 10.10.163.35 SSID-X AP ee:a0:7f:c9:e2:68 default 84 WPA-TKIP 0 FORWARD_TUNNEL_80211 SSID-X-aaa_prof/SSID-X-dot1x_prof
ee:a0:7f:1e:26:83 10.10.163.35 PSKSSID AP ee:a0:7f:c9:e2:68 default 810 WPA-PSK-TKIP 0 FORWARD_TUNNEL_80211 PSKSSID-aaa_prof/PSKSSID-dot1x_prof
ee:a0:7f:1e:26:81 10.10.163.35 SSID-A AP ee:a0:7f:c9:e2:68 default 94 WPA-TKIP 0 FORWARD_TUNNEL_80211 SSID-A-aaa_prof/SSID-A-dot1x_prof
ee:a0:7f:1e:26:80 10.10.163.35 SSID-X AP ee:a0:7f:c9:e2:68 default 84 WPA-TKIP 0 FORWARD_TUNNEL_80211 SSID-X-aaa_prof/SSID-X-dot1x_prof
John Davis
Original Message:
Sent: Feb 14, 2022 07:48 PM
Subject: Verifying Encryption type of Client Association.
Incorrect. It shows encryption for all types
Original Message:
Sent: Feb 14, 2022 05:04 PM
I wanted to try to clarify that this command "show dot1x supplicant-info list-all" will only show devices for dot1x SSIDs, correct?
Is there a similar command for current devices connected to pre-shared key SSIDs?
Thank you,
John
John Davis
Original Message:
Sent: Oct 25, 2018 11:54 AM
Yes, that command is helpful too if you want to show the essid's encryption type. But I was looking for a command that shows what encryption type client is using to connect to a profile and "show dot1x supplicant-info list-all" does that by showing client MAC along with the specific encryption type. Thank you for your input.
