Some differences between Cisco and HP:
Trunk [HP] = Port-channel
Trunk [Cisco] = 802.1Q
You don't apply VLAN configurations to ports, instead you apply port information to the VLANs.
Ex: VLANs 1 and 5 [Cisco: Trunked] on port gig 0/1 with VLAN 1 being untagged.
vlan 1
name "CORP"
untagged 1
ip address 10.1.10.254 255.255.255.0
exit
vlan 5
name "guest"
tagged 1
ip address 10.1.20.254 255.255.255.0
ip helper-address 10.1.10.22
exit
You use the tagged and untagged commands to specify the port VLAN configuration.
