Very Odd behavior with the LED Status
  • 1.  Very Odd behavior with the LED Status
    Posted Apr 13, 2017 05:17 AM
    I'm writing you because I'm starting to loose my latin about this behavior...
    I've got a controller with a bunch of AP 105, 114 and 275...
    The normal LED status ( in my case ) all the led are green :)
    Since I've removed one unused SSID ( not set with the n), le BGN led is now "amber" which means that the "n" is not enabled....
    I've checked on the controller and I can see clients associate with "n" and under the "High Throughput SSID profile" the High throughput is enabled...
    Who I need to trust ? the AP or the controller?
    thanks in advance
  • 2.  RE: Very Odd behavior with the LED Status
    Posted Apr 13, 2017 05:40 AM
    The LED on all the access points is Amber?  Do you know if it is the power LED, the ethernet LED or the WLAN LED(s)?
  • 3.  RE: Very Odd behavior with the LED Status
    Posted Apr 13, 2017 05:43 AM
    Hello Joseph,
    i' hope your fine !
    all LED are green, except the 2.4 BGN is now amber since i've removed an old SSID.
    the odd things is that i can see clients with " n20mhz"
    why ...
  • 4.  RE: Very Odd behavior with the LED Status
    Posted Apr 13, 2017 05:46 AM
    Did you add an SSID?  You should look at the output of "show ap essid" on the commandline of the controller to see if you might have added an SSID" that is WEP, or just WPA.
  • 5.  RE: Very Odd behavior with the LED Status
    Posted Apr 13, 2017 05:49 AM
    no, just remove an old one.
    below the results :
    ESSID APs Clients VLAN(s) Encryption
    employe 122 20 40 WPA2 PSK AES
    Guest 107 6 50 WPA2 PSK AES
    VoIP 122 58 30 WPA2 PSK AES
    Num ESSID:3
  • 6.  RE: Very Odd behavior with the LED Status
    Posted Apr 13, 2017 06:07 AM
    What kind of SSID did you remove?
  • 7.  RE: Very Odd behavior with the LED Status
    Posted Apr 13, 2017 06:10 AM
    wlan ssid-profile "RTLS"
    essid "rtls"
    opmode wpa2-psk-aes
    a-basic-rates 12 24
    a-tx-rates 12 24 36 48 54
    g-basic-rates 12 24
    g-tx-rates 12 18 24 36 48 54
    wmm-vo-dscp "46"
    wmm-vi-dscp "34"
    wmm-be-dscp "10"
    wmm-bk-dscp "0"
    ht-ssid-profile "No-HT"
    dot11r-profile "default"
  • 8.  RE: Very Odd behavior with the LED Status
    Posted Apr 13, 2017 06:14 AM
    I would type "show audit-trail" and go through it line by line to ensure that you did not remove "HT" somewhere in your configuration by accident.
  • 9.  RE: Very Odd behavior with the LED Status
    Posted Apr 13, 2017 06:21 AM
    seems to ne not :/
    Mar 31 08:54:01 webui[3875]: USER:admin@172.18.40.67 COMMAND:<wlan virtual-ap "VAP-RTLS" > -- command executed successfully
    Mar 31 08:54:01 webui[3875]: USER:admin@172.18.40.67 COMMAND:<wlan virtual-ap "VAP-RTLS" no vap-enable > -- command executed successfully
    Mar 31 08:54:09 webui[3875]: USER:admin@172.18.40.67 COMMAND:<write memory > -- command executed successfully
    Mar 31 08:58:18 webui[3875]: USER:admin@172.18.40.67 COMMAND:<wlan ssid-profile "SSID-RTLS" > -- command executed successfully
    Mar 31 08:58:18 webui[3875]: USER:admin@172.18.40.67 COMMAND:<wlan ssid-profile "SSID-RTLS" no ssid-enable > -- command executed successfully
    Mar 31 08:58:27 webui[3875]: USER:admin@172.18.40.67 COMMAND:<write memory > -- command executed successfully
    i've sent the whole on private message
  • 10.  RE: Very Odd behavior with the LED Status
    Posted Apr 13, 2017 06:54 AM
    I don't see anything that would cause the LED to be orange in there.  You might have to open a case to get to the bottom of this...
  • 11.  RE: Very Odd behavior with the LED Status
    Posted Apr 13, 2017 07:01 AM
    Thanks Joseph for you analyze
    he couldn't be a mix that the HT settings are different between the SSID ?
    Or nothing related to the MIMO ?
  • 12.  RE: Very Odd behavior with the LED Status
    Posted Apr 13, 2017 07:09 AM
    It would seem that the VOIP SSID has a no High Throughput Parameter:
    wlan ht-ssid-profile "HT-VoIP"
    no 40MHz-enable
    no very-high-throughput-enable
    wlan ssid-profile "SSID-VoIP"
  • 13.  RE: Very Odd behavior with the LED Status
    Posted Apr 13, 2017 07:22 AM
    no very-high-throughput-enable = No AC enable right ? or no AC and N ?
    As attached, i can see clients with radio PHY et client PHY with N 20mhz
    normal ?
  • 14.  RE: Very Odd behavior with the LED Status
    Posted Apr 13, 2017 07:33 AM
    HT is 802.11n.  Why is "No HT" in that config?  That would fix your issue.
  • 15.  RE: Very Odd behavior with the LED Status
    Posted Apr 13, 2017 07:35 AM
    it means that if a enable : very-high-throughput-enable it will bring the led light back to green ?
    why i'm able to see clients with "n 20mhz" ?
    what does it means ?
  • 16.  RE: Very Odd behavior with the LED Status
    Posted Apr 13, 2017 07:44 AM
    I am not sure why it would say HT, but the no high throughout is what would be causing your issue.
  • 17.  RE: Very Odd behavior with the LED Status
    Posted Apr 13, 2017 07:48 AM
    look attached, it's activated ...
  • 18.  RE: Very Odd behavior with the LED Status
    Posted Apr 13, 2017 08:01 PM
    I am not sure that is what your config says.  Is it possible that you didn't do a "write mem" or save configuration on the master controller?
  • 19.  RE: Very Odd behavior with the LED Status
    Posted Apr 25, 2017 03:35 AM
    i did...
    Now all the led are green except the A/N which is amber...
    very odd...
  • 20.  RE: Very Odd behavior with the LED Status
    Posted Apr 25, 2017 07:20 AM
    You might want to open a TAC case in parallel so that they can look over your entire configuration.  There could be something there that is enabled or it could be a bug..
