VHT Not Operational - Sanity Check
  • 1.  VHT Not Operational - Sanity Check
    Posted Aug 18, 2015 11:29 AM
    I enabled VHT on a set of AP-225s using AP specific configs, yet my 11ac clients are associated a-HT mode.  I verified that VHT is checked in the radio profile and in the HT SSID profile.  Here are the outputs to confirm the radio is running int VHT:
    (controller) #show ap active | include AP01
    AP01 XXXXXX X.X.X.190 0 AP:HT:6/12/21 8 AP:VHT:165/15/22 225 A2da 64d:11h:19m:50s N/A
    (controller) #show ap bss-table | include AP01
    6c:f3:7f:XX:XX:XX TEST-SSID N/A X.X.X.190 a-VHT ap 165/15/22 8 AP01 0 23d:6h:49m:24s 1500 - 2 T
    I also did a packet captured and verified that the VHT field is not being advertised in the beacons.
    I need a sanity check... what am I missing?
    #AP225
  • 2.  RE: VHT Not Operational - Sanity Check
    Posted Aug 18, 2015 11:33 AM
    I would try disconnecting a client and letting it attach back.
  • 3.  RE: VHT Not Operational - Sanity Check
    Posted Aug 18, 2015 11:34 AM
    This has been over the course of a few days, so clients have disconnected/reconnected multiple times.  The fact that the VHT field is not being advertised in the beacons tells me VHT mode is not actually enabled.
  • 4.  RE: VHT Not Operational - Sanity Check
    Posted Aug 18, 2015 11:47 AM
    When you do a show ap association, for the clients under test, what do you see?\
    http://community.arubanetworks.com/t5/Mobility-Hero-Tutorials/ArubaOS-6-3-and-Above-802-11ac-Enable-VHT-even-if-you-are/ta-p/145689
    Might have TAC take a look at firmware, config, and pcap to see why the VHT isn't advertising in the beacons.
  • 5.  RE: VHT Not Operational - Sanity Check
    Posted Aug 18, 2015 11:53 AM
    What version of ArubaOS is this? There is a bug where that could happen.
  • 6.  RE: VHT Not Operational - Sanity Check
    Posted Aug 18, 2015 12:11 PM
    Jay
    is your AP deliberately being forced to ch165 for some reason (or has arm spazzed out) ? that is not part of the 80 Mhz plan, which is 149-161.. check for rogue ap-name and rf dot11a profile
    regards
    -jeff
  • 7.  RE: VHT Not Operational - Sanity Check
    Posted Aug 18, 2015 12:58 PM
    Jeff,
    Yes, I added 165 to the regulatory domain. We're using 20mhz channels.
    I did have other APs on different channels not running in VHT.
    Colin,
    I can open a TAC case if you believe it's a bug.
  • 8.  RE: VHT Not Operational - Sanity Check
    Posted Aug 18, 2015 01:09 PM
    ahhh.. duh.... my miswording - can you try changing it out of 165 ? the point I was more thinking (but not saying) was that 165 is not commonly used where "defaults and VHT are used" and it might be a glitch for non 40/80 mhz channel.
    but, having said that, just to try it - forced 165 + ap205 + 7260 works ok (6.4.3)
    ap205  ac:a3:1e:b7:df:30  5c:c5:d4:7c:a3:44  y     y      1    250    v1-7030-psk  1        0x1001b    a-VHT-20sgi-2ss  10s          1          WAB    0/0
    strange one, if it starts working on channel change it will definitely be useful info for a ticket.
    regards
    -jeff
  • 9.  RE: VHT Not Operational - Sanity Check
    Posted Aug 18, 2015 02:24 PM
    Colin,
    6.4.2.8
    Jeff,
    Now this is interesting... I have two SSIDs on 5GHz.  One is advertising VHT in beacons, the other is not.  Both share the same HT SSID w/ VHT enabled.  I checked the AP on channel 165 and the VHT field is there for the 'secondary' SSID.
    This seems like a bug to me.
  • 10.  RE: VHT Not Operational - Sanity Check
    Posted Aug 18, 2015 03:47 PM
    TAC case open.  Sanity check cleared. :)  The engineer is trying to reproduce the issue in his lab.
  • 11.  RE: VHT Not Operational - Sanity Check
    Posted Aug 18, 2015 07:14 PM
    Thecompnerd,
    The bug is if dot11a-radio-profile VHT is disabled and ht-ssid-profile is enabled, it does not enable VHT.  Try checking to see if both the dot11a-radio-profile and ht-ssid-profile are both enabled.
  • 12.  RE: VHT Not Operational - Sanity Check
    Posted Aug 18, 2015 07:17 PM
    They are.
  • 13.  RE: VHT Not Operational - Sanity Check
    Posted Aug 18, 2015 07:23 PM
    In summary, the bug is disabling, then enabling VHT in the 802.11a radio profile does not re-enable VHT.  Please let us know what TAC says.
  • 14.  RE: VHT Not Operational - Sanity Check
    Posted Aug 18, 2015 10:38 PM
    Based on your response, I decided to fool with it this evening after all the users left and got VHT working for all SSIDs.  Here's what I did:
    1. Disabled VHT under HT SSID profile.  Saved settings
    2. Waited and confirmed a-HT mode on APs.
    3. Enabled VHT under HT SSID profile.  Saved settings.
    I setup a remote capture and confirmed the VHT field is now advertised in beacons for all the APs' BSSIDs.  Also, checked ap associations and verified I have VHT clients connected.
    This is reproducable.  I disabled VHT in the HT SSID profile and radio profile and saved changes.  Verified APs were back to a-HT mode.  Then, I enabled VHT under both profiles and confirmed VHT was only advertised by one SSID.  Disabled/enabled VHT mode under HT SSID profile and verified BOTH SSIDs advertised VHT.
    Does this describe the bug you're aware of?
  • 15.  RE: VHT Not Operational - Sanity Check
    Posted Aug 24, 2015 10:18 PM
    TAC was able to reproduce with version 6.4.2.8, but indicated the issue is resolved in 6.4.2.12.
