I am using VIA on Win 7, iOS, OS X and Android platforms (all in the same environment) and would like some clarification on VIA's split tunneling capability/configuration, specifically:
1) Other than defining the Tunneled Networks under the VIA config profile, and checking "Enable Split Tunneling" under the same profile, is there anything else required for enabling split-tunneling specifically for VIA users?
2) The latest VIA notes I can find state the Mac OS X 1.x client is not compatible with split tunneling. In a mixed-device environment can I utilize one VIA config profile (with ST enabled) and still support OS X clients, or do they need their own config profile?
3) Despite defining tunneled networks and enabling split tunneling under the VIA config profile, split tunneling does not appear to be working for me under Win 7 (VIA 2.1.1.0.35555). As indicated in #1 are there any additional steps necessary to turn this on?
I have VIA working in general and can access internal networks, however the split tunneling feature specifically does not work under Win 7 (but works under Android), and there does not appears to be much guidance in the App Notes or User Guide on configurations/compatibility for this functionality. Please advise, thanks!
