Hi, in october microsoft will deliver patches which will affect certificates because the system will put all certifcates with a RSA-Key shorter then 1024-bit out of order. Where can i check if my system uses such certificates for VIA?
Thank You
Do you enter username and password for VIA or do you issue client-side certificates for authentication?
If you are using client-side certificates for authentication, those should not be affected.
we are using a username and password for via. So the whole certificate-issue doesn't matter for us?
